| ShipConstructor Help I want to make a bracket with folded plate system. How to make a folded plate bracket in shipconstructor ? |
| If your making a standard bracket in Manager you might be able to add a folded flange to it before you save it. I've never tried it so it might not work, you'd need to make the folded flange rule before had though. I'd be pretty surprised if that did work but I'd try that one first. If that doesn't work you could try making it as a part in Standard assembly as you have greater access to the plate editing tools. It would work there and when you insert you can specify that the plate keeps the Standard Assembly name. |
| shipconstructor ? | Kikisak1980 | Software | 21 | 08-30-2011 02:44 AM |
| Shipconstructor anyone? | Emil_h | Software | 3 | 04-30-2009 08:33 AM |
| ShipConstructor...Help | ringoo83 | Software | 12 | 04-16-2009 04:05 AM |
| Shipconstructor need help | xhanasico | Software | 0 | 11-03-2007 10:21 AM |
| shipconstructor | Morgig | Software | 1 | 07-29-2005 09:26 AM |
