| Shell expansion drawing by Rhino using squish plug-in By squish plug-in we can expand one plate at a time. Is there any way to expand more than one surface together, to make a traditional shell expansion drawing?
__________________ Md. Al-Amin Pavel http://www.paveldesign.tk "A question that sometimes drives me hazy, am i or are the others crazy?" Albert Einstein |
| Do you mean to expand multiple plates as a single action or to expand two-surfaces linked together? I don't believe you can use this function on multiple surfaces at once. You'll have to expand each singularly then lay them out. Is this the plug-in you are using or do you have another? http://wiki.mcneel.com/labs/advancedflattening I've found it pretty useful as it can flatten complex curvature but sometimes it produces results that are clearly wrong, so I've had to use it quite carefully.
__________________ -Drew |
| To do a traditional shell expansion in rhino you have to do manual. |
| ACuttle i means expanding morethan one surface together, when i have splitted the hull surface according to my desired distribution of shell plates. And micspoko, yes I do agree with you... but I hope rhino will develop plug-in which will really help in our shell expansion.
| i also have a hope |
| Problem with Workshop (Shell expansion dwg) | NavalDesigner39 | Software | 3 | 09-26-2010 03:58 AM |
| Traditional Shell expansion drawing in Rhino | pavel915 | Software | 4 | 04-05-2008 08:22 AM |
| Drawing surfaces of the bulb in Rhino | toda | Software | 7 | 04-19-2007 06:18 AM |
| shell expansion and midship section drawing in workshop | pavel915 | Software | 5 | 02-27-2007 02:27 AM |
| unroll surface in rhino for shell expansion | pavel915 | Software | 4 | 02-16-2007 07:35 AM |
