Old 03-02-2006, 12:36 PM
oceangboy2000 oceangboy2000 is offline
Rep: 10 Posts: 20
Shape vs. Surface
Hey everyone, just a quick question. Ive been useing maxsurf here at school for quite sometime now and still no one seems to be able to put their finger on this one. In maxsurf what exactly is the defferance in adding a surface vs. added a shape? Thanks is andavce for any input on this one! ~dan
Old 03-02-2006, 04:55 PM
Rep: 206 Posts: 391
The difference is that adding a surface adds a single surface from a list of choices in a menu. This function is customisable so that you can design a template surface (e.g. a keel) and add it to the Add Surface menu list for future use as a standard surface.
Add shape just covers a set of commonly used primitives (sphere, hemisphere, box etc.) that need multiple surfaces to construct a fully closed object. The Add Shape menu also allows you to choose size and rotation, and even symmetry properties, prior to the shape being added.
Because of the additional level of detail required, the Add Shape command can't be added to in the same way that Add Surface can.
Hope this explains things.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Best shape for surface piercing foil grob Sailboats 48 11-23-2010 04:47 PM
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
Shape of extrusions Celine Boat Design 6 01-06-2006 05:42 AM
Hull Shape mrbrown Boat Design 1 08-09-2004 11:24 AM
transom shape Ryon Macey Powerboats 4 02-18-2002 07:32 AM
