| SC advice needed Hello all, I have recently started working with shipconstructor 2006 and was hoping to get a little help regarding brackets. I'm working on a 100' tug and I will have vertical angle iron stiffeners on some of my bulkheads and brackets attached to the stiffener tops and bottoms. SC has a standard part feature which is nice but in many cases the brackets that I need to create are not standard and will need to take the shape of the hull. So i'm trying to figure out the best way to create these custom brackets. Do I need to create a new planar group for each bracket or is there some other way to go about creating multiple custom brackets?Thanks in advance. |
| Well I thought there would be some shipconstructor guys on these forums. ![]() |
| Each Brkt is made from a Pline to form a solid. They can be made in one Plane Grp and copied to as many as you want. Change shape or location as desired. |
| Thanks for your response jmurf. Another question, if you will sir. When marking group intersections, do you use solids or moldline, or something else? Thank again. ![]() |
| Sc Workboat The moldline is usually the side to etch/mark. |
| Duoprop Compatibility - advice needed | BJB | Sterndrives | 6 | 09-12-2006 06:25 PM |
| Advice needed for foam job | Frosty | Fiberglass and Composite Boat Building | 12 | 08-19-2006 02:27 AM |
| Hi everyone.. Advice Needed | LoneRider | Open Discussion: All Things Boats & Boating | 10 | 06-23-2006 12:55 AM |
| Advice Needed | KSC | Boat Design | 1 | 02-20-2005 10:44 PM |
| Advice needed! | biggathanjesus | Materials | 6 | 05-28-2004 11:44 AM |
