  #76
Old 05-23-2007, 09:11 AM
Dingo's Avatar
Dingo Dingo is offline
Naval Architect
Rep: 67 Posts: 40
Latest Spreadsheet
Here is the Planing spreadsheet with the correction for the trim tabs. Sorry for any inconvienence!
Has anyone looked and used the theory in the paper "A Rational Prismatic Hull Approach for Planing Boat Analysis" by Richard A. Royce, Jan 1994, SNAME local section paper of the Great Lakes (also on the Small Craft CD)?
Dingo Tweedie
  #77
Old 05-26-2007, 11:20 AM
Dingo's Avatar
Naval Architect
Rep: 67 Posts: 40
Lewandowski
I was asked by CGN on another thread what the section by Lewandowski is for on the spreadsheet Planing.xls
This paper set out the dynamic stability for a planing vessel. For a given angle of roll, the restoring moment in ft-lbs is calculated (note: a negative moment means a restoring moment, positive is non-restoring).
Dingo Tweedie
  #78
Old 05-26-2007, 02:14 PM
CGN CGN is offline
Rep: 121 Posts: 547
Thanks dingo, I much appreciated your help
cheers
  #79
Old 05-01-2008, 09:40 PM
Janamon Janamon is offline
Rep: 10 Posts: 10
Hi Dingo.
I'm working through your excel spread sheet. Have you a copy in English. I just can't work out some of your symbols. If you could help me that would be great.
Cheers John H
ngaire_john@xtra.co.nz
  #80
Old 06-09-2008, 05:34 AM
vankamal07 vankamal07 is offline
Rep: 10 Posts: 3
who can guide me?
i am new here, and a young naval arc, i want to predict my boat using savitsky method because what i know this method suitable for planning hull.
so i had got all the particular from that formula, but i still confuse with one thing, my boat length overall is 12.0 meter, and LWL is about 10.33 and her draught is 0.53 meter.
what the problem i get, when i calculate the Lk from the savitsky method it give larger than my length's boat. why? and it give the effect for power prediction i getting. here i attached for you the results i get. i just attached the Lk result and speed and power prediction i get only.i just want know, it is what i get is correct or false to compare with my length of boat.
please help me senior and junior :rolleyes:
  #81
Old 06-11-2008, 09:19 PM
Dingo's Avatar
Naval Architect
Rep: 67 Posts: 40
Lk
vankamal07,
Please give me more details on your vessel especially LCG, displacement, speed etc. I can't analyze any results without knowing more about the vessel. One thing I can tell you is if the LCG has been assumed incorrectly, the value of Lk will vary. Note that Savitsky's method does not take into account the length of the vessel since the beam dimension is what gives it its lift. The length only comes into play to calculate wind resistance etc.
Dingo
Dingo Tweedie
  #82
Old 06-11-2008, 11:07 PM
Rep: 10 Posts: 3
Thank dingo for your co-operation,
Here i state the particulars of my boat and the results i got.
Boat's particulars:
Weight = 4.5 tonnes,
Estimation LCG = 4.72m from transom,
Beam = 2.76m
Deadrise = 15 degree
Results:
Based on Savitsky's method, i got
at 50 knots,
λω = 2.414,
trim = 1.452,
Lk = 11.31 m
Ds = 0.29
Stotal= 19.03
EHP (hp) = 551.7 hp
So , i hope u can tell me what wrong in my calculation.
  #83
Old 06-14-2008, 03:49 PM
Dingo's Avatar
Naval Architect
Rep: 67 Posts: 40
Vankanal07, I could not get the results exactly that you had since I still do not know your VCG, angle of shaft etc. What I did notice is that under the comments column, it displayed "Note: Not Planing". This method is used only for planing vessels, so Lk could be wrong for your vessel.
Dingo Tweedie
  #84
Old 06-16-2008, 05:19 AM
Rep: 10 Posts: 3
dingo i appreciate on your help, i am new in this field, so i don't have enough knowledge an experienced, i hope u can guide me...dingo can u give me the methods of your calculation...so that i can study on and find the answer from it...
  #85
Old 06-16-2008, 08:50 PM
Dingo's Avatar
Naval Architect
Rep: 67 Posts: 40
References
If you look inside the tab entitled "Berekenings", you will see all the calculations. On the very right-hand side of the columns I have listed all the references and papers which I used. Hope this helps.
Dingo Tweedie
  #86
Old 06-18-2008, 05:45 AM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 614 Posts: 720
Demi hull Cat
What is the best method to predict the performance of a demi hull planing catamaran? The flat side of the hull is located inboard. Section shape looks like a tunnel boat.
  #87
Old 08-29-2008, 04:28 AM
rahaman rahaman is offline
Rep: 10 Posts: 6
Dear Dingo Tweedie,
I have found your latest planing spreadsheet. It is very nice work. Thank you very much for sharing your excellent work . Is it possible for you to provide the password of your spreadsheet? I want to do some calculation by using your spreadsheet for my graduate report and I have to submit my report on next Tuesday(2/9/2008). So, if possible please........
Thank you once again.
Rahaman Md. mashiur
  #88
Old 08-29-2008, 06:04 PM
Dingo's Avatar
Naval Architect
Rep: 67 Posts: 40
Password for Planing.xls
Dear Rahaman,
The spreadsheet should work without needing a password. All calculations and formulas are visable, and the macros work. If the spreadsheet has a problem running, let me know.
Dingo Tweedie
  #89
Old 08-31-2008, 10:39 AM
Rep: 614 Posts: 720
Rahaman,
You may try copying the sheet to another spreadsheet. You will lose some macro but the cells can be edited. Dont edit the formulas however.
Dingo,
I tried this to disable the password because I have an officemate who is Dutch Afrikan. He says the words are in Dutch German. He was able to translate closely most of the word anyway. I find your work very complete and I want to know how everything connects so I need to decipher some words.
Rx
  #90
Old 08-31-2008, 10:17 PM
Dingo's Avatar
Naval Architect
Rep: 67 Posts: 40
Password for Planing Sheet
The reason that I lock the spreadsheet is so that no one can tamper with it and re-post it, or submit it as homework by tweaking it and calling it their own. It took me a long time to write it, but, for the purposes for sharing engineering knowledge, I allow the formulas to be seen, and all the macros to be read. Nothing should be hidden; all references are also able to be read (see the right hand side in Berekenings). I am willing to explain my logic and any translations required if asked. I hope that this seems reasonable.
Dingo Tweedie
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
Help with Savitsky Prediction and shaft inclination fede Boat Design 4 06-08-2005 08:08 PM
Article on converting 43-footer to diesel-electric propulsion lockhughes Open Discussion: All Things Boats & Boating 13 09-01-2004 08:14 PM
