#46
| I have a copy of the Savitsky method applet published by Arneson (somewhere) . If I remember correctly, it is a very "short form" and simplified Savitsky power prediction method - assumes thrust line passes through CG, etc. Dingos' work in Exel exposes the calculations and formulas, which is really cool for gaining an underdstanding of what is behind "the answer." Chris Krumm |
#47
| Savitsky Yes, the program was very simple. Keep up the good work chris. We are all in search of "what happens if?". Dingos work is great. I have to find my copy of SNAME's publication on planing craft to decipher the formulas. |
#48
| Same modeller for a Stern drive application Hi all We make a new stern drive leg and are looking for a application that we can use to not only predict vessel speeds, gearing prop diameter and pitch. Since the leg doesnt contain a gearbox, the drive uses a ZF 8 degree downangle box, which attaches to the drive. Now what way would I do this is there no strut, rudder, shaft etc but planing hull? Im trying to figure this out, looks like this is very close Can you give me any hints please Regards Darren Finch DBD Marine www.dbdmarine.com
__________________ DBD Marine Po Box 54 Edgewater NJ 07020 Ph 201 295 1441 cel 201 232 1740 email sales@dbdmarine.com |
#49
| There is a Savitsky spreadsheet available on the web at www.hawaii-marine.com/templates. It does not use Excel's Solver or macros or Visual Basic. It does the iterations automatically and evaluates several speeds. It does both the Short and Long Forms of Savitsky's methods. |
#50
| savitsky/CFD combined procedure Hi all, I am a new member of the forum. I found the spreadsheet of Dingo really interesting. I'm interested in making a slight modification on it in order to input manually the resistance forces that I obtain from a CFD planing computation. The procedure may be the following: 1. determine the position of the boat with the Dingo's spreadsheet 2. compute the drag and lift forces acting on the hull via a CFD free-surface computation (with sink&trim from step 1.) 3. insert the CFD-computed drag estimates at the various speeds in the spreadsheet and re-run the computation uptating sink&trim 4. return to step 2. until convergence... I have to say that I want to make CFD computations only of the hydrodynamic part computing viscous and wave resistance, but without simulating spray formation (almost impossible to get reliable spray-induced-drag up to date). So the results I get are only a part of the total drag/lift. Dingo could you suggest me where I should input my CFD drag/lift forces? I think the "Berekenings" sheet, but where? How the spray formation and aerodynamic forces are taken into account? Thanks Michele. |
#51
| Input Micheler, I will look into where putting the CFD results should go. Lines 78 to 83 is where the input for the air drag due to superstructure is placed. This can be modified for lift also but then the total moments must then be recalculated (add lift due to s/str in line 13). Please note that my e-mail address has changed. It has also come to my attention that the calculations when using a trim-tab might be slightly off. I will look into it and re-post the spreadsheet if incorrect and as soon as I have time. Sorry for any problems.
__________________ Dingo Tweedie |
#52
| Be careful using CFD, there may be a lot of instances with multi-phase flow. You also have a trim question to get right. Dingo, you don't have a copy of the SNAME Savitsky paper do you? Tim B.
#53
| Savitsky paper Tim B, I do have a copy of Savitsky's 1964 paper at SNAME, but it is not the only paper that I used for my spreadsheet. All references are quoted in the spreadsheet in the 'Berekenings' section.
#54
| Ok, I'll have a look at it sometime, I'd really like to add a Savitsky method to LMH at some point, but it will need to be written in C/C++. It also infers that LMH should be finished... yeah, Christmas perhaps. Cheers, Tim B.
#55
| hydrodynamic forces computations Thanks for your replies. I'm trying to understand the "Berekenings" section. But I haven't the Savitsky paper so I have some questions. I'm especially interested in the first part of the section, where the Savitsky method is applied for computing the planing hull resistance (up to row #43). For computing the resistance, it seems that the Schoenherr '32 + the ATTC Ca of 0.0004 are applied on the Sf area. What does the Sf (=lambda * B^2 / cos (beta_e) ) area exactly represents? Why the Df force is computed with the 0.97 factor instead of the more usual 0.5? What it accounts for? Is it a correction for spray formation? Or is it merely a units conversion factor? After computing all force components, it is applied an M-factor. What does this correction stands for? Thanks Michele. |
#56
| Hi Hi, Its great to hear from u that "Dingos' work in Exel exposes the calculations and formulas, which is really cool for gaining an underdstanding of what is behind "the answer." ". I would like to have that copy, can u send it to me Subbu |
#57
| Hello All, Is the planing equations applicable to rounded bilged hulls? (i.e. modern round bottomed beach-cats). The question could also be read: Are the equations valid for long, skinny and rounded hulls? If not, at what are the input limits for the equations? Best Regards Patrik Best Regards
__________________ Patrik Elfving |
#58
| Could deadrise for instance be approximated as some sort of average over the curved surfaces? Anyone have some sort of hint??
#59
| deadrise Quote:
If the keel has a fairly rounded section, it should be measured from the point tangent to the radius to the edge of the chine. If you have a reverse chine, the edge of the chine pointing downward is still the edge. |
#60
| I've run Dingo's program on a number of occaisions since he 1st (very kindly) made it available to us all. I don't doubt the validity of the calculations, but perhaps someone might be able to give me a definitive means of interpereting them.... For instance, I ran the numbers thru for a 40 footer powered by a single duoprop sterndive (hence the zero entries for rudder, strut etc...) with the following results: Inputs Hull Beam B 10.53 feet VCG VCG 3.31 feet = 1.009 metres Displacement D 14,265 lbf = 6,471 kg Deadrise @ Transom b T 9.3 ° Deadrise @ Amidships b )0( 15 ° Distance to Amidships L )0( 14.400 feet = 4.389 metres f 3.60 feet = 1.097 metres e 0.00 ° q 2.182 ° Minimum Speed Vmin 6.5 kn = 11.0 feet/s This is the minimum speed valid for this analysis Maximum Speed Vmax 141.8 kn = 239.3 feet/s This is the maximum speed valid for this analysis Number Number of Propellers N 1 Trim Tab Chord cF 1 feet = 0.305 metres Span Ratio s 0.32 ( <= 1 ) Deflection Angle d 0 ° Rudder Chord crudder 0.00 feet = 0.000 metres Thickness t 0.00 feet = 0.000 metres Area Arudder 0.00 feet2 = 0.000 m2 Centrepoint xc 0.00 feet from transom = 0.000 metres (+ve fwd) yc 0.00 feet from baseline = 0.000 metres (+ve up) Shaft Diameter of Shaft Fshaft 0.00 feet = 0.000 metres Length of Shaft & Hub l 0.00 feet = 0.000 metres Centrepoint xc 0.00 feet from transom = 0.000 metres (+ve fwd) yc 0.00 feet from baseline = 0.000 metres (+ve up) Strut Chord cstrut 0.00 feet = 0.000 metres Thickness t 0.00 feet = 0.000 metres Area Astrut 0.00 feet2 = 0.000 m2 **** Centrepoint xc 0.00 feet from transom = 0.000 metres (+ve fwd) yc 0.00 feet from baseline = 0.000 metres (+ve up) Output V LCG t D T Peffective h [kn] [ft] [metres] [°] [lbf] [kN] [lbf] [kN] [ehp] [ekW] [ft] [metres] 6 10.5 3.2 4.9135 786 3.5 790 3.5 14 11 2.71 0.826 7.5 10.5 3.2 5.4956 1,061 4.7 1,069 4.8 24 18 2.80 0.853 10 10.5 3.2 6.7204 2,011 8.9 2,029 9.0 62 46 2.90 0.884 12.5 10.5 3.2 7.4953 2,437 10.8 2,465 11.0 93 70 2.77 0.844 13 10.5 3.2 7.518 2,465 11.0 2,493 11.1 98 73 2.72 0.829 14 10.5 3.2 7.4427 2,478 11.0 2,505 11.1 106 79 2.59 0.789 15 10.5 3.2 7.2444 2,451 10.9 2,477 11.0 113 84 2.45 0.747 17.5 10.5 3.2 6.4822 2,313 10.3 2,333 10.4 124 93 2.11 0.643 20 10.5 3.2 5.6434 2,175 9.7 2,190 9.7 133 100 1.82 0.555 25 10.5 3.2 4.2328 2,034 9.1 2,043 9.1 156 116 1.40 0.427 30 10.5 3.2 3.2351 2,067 9.2 2,073 9.2 190 142 1.13 0.344 35 10.5 3.2 2.5363 2,227 9.9 2,232 9.9 239 179 0.94 0.287 40 10.5 3.2 2.0349 2,483 11.0 2,487 11.1 305 227 0.82 0.250 45 10.5 3.2 1.6647 2,815 12.5 2,818 12.5 389 290 0.72 0.219 50 10.5 3.2 1.384 3,210 14.3 3,213 14.3 493 368 0.65 0.198 ...hmmm I see that the table doesn't line up all that well, but the long and the short of it is that at my target max speed of 25 knots, the spreadsheet gives a required effective hp of 156hp. So, the question - how to relate this to SHP or even better, a published engine / propeller curve....?
| Auto engine marinization | DIY Marinizing | 231 | 07-01-2010 08:34 PM | |
| Option One - how big | Willallison | Option One | 43 | 12-20-2005 06:44 AM |
| Help with Savitsky Prediction and shaft inclination | fede | Boat Design | 4 | 06-08-2005 08:08 PM |
| Article on converting 43-footer to diesel-electric propulsion | lockhughes | Open Discussion: All Things Boats & Boating | 13 | 09-01-2004 08:14 PM |
