Old 02-19-2005, 02:00 PM
ivansalasj ivansalasj is offline
Rep: 10 Posts: 63
Sails in Maxsurf
Hi,
I am trying to design a genoa and a main sail on top of a yacht that i have designed using maxsurf, but i am finding it very hard specially because my mast seems to be cutting a bit of the genoa. Can anybody suggest me a good way to draw the sails in maxsurf?
Thanks
Ivan
Old 02-19-2005, 10:28 PM
DaveB DaveB is offline
Rep: 11 Posts: 128
sailcut
Hi,
I'd recommend sailcut, or the new sailcut cad... (haven't used the new one, but like the old one, so imagine it would be as good or better). You can use it to get panel shapes, then import dxf file as markers n' draw the surfaces to fit if that's your ultimate goal...
http://sourceforge.net/projects/sailcut/
Cheers,
Dave
Old 02-20-2005, 07:52 AM
Rep: 10 Posts: 63
Hi
Thanks for the advice, i dont need surfaces really so i will see if i can get hold of that program and try it there then,
Thanks again
Ivan
Old 02-20-2005, 08:15 PM
Rep: 206 Posts: 391
Ivan
Do you want to model the sails in Maxsurf simply for rendering (should be straightforward) or do you actually wish to use Maxsurf to design the sails for manufacture (not recommended).
If you wish to do serious sail design I would recommend looking into the dedicated sailmaking programs.
regards
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 02-23-2005, 05:58 AM
JimCooper JimCooper is offline
Rep: 10 Posts: 81
I use a few stock sail shapes in Rhino and export the Maxsurf model to Rhino for rendering and art work detail.
A freind gave me a few main sails and headsails from one of the sail making software packages and I distort them to suit, works well for basic graphics
Old 02-23-2005, 06:48 AM
ludesign ludesign is offline
Rep: 60 Posts: 185
I can direct import actual sails into TouchCAD from Sails Science Sailmaker using a built in import filter in TouchCAD. The enclosed image from the TouchCAD web site shows an example where everything but the sail was modeled in TouchCAD.
Claes Lundstrom
Old 03-02-2005, 06:50 PM
boby boy boby boy is offline
owner of cla boat design
Rep: 10 Posts: 32
what version of maxsurf are you using
signed boby boy
make life fun :)
Q. Lines-planes form AutoCAD to Maxsurf ? cmcguinness Software 0 12-06-2004 05:02 PM
a newer involved in maxsurf jennifer Software 4 07-06-2004 09:28 AM
AC yacht modelling accurately on Maxsurf?? ac4ever70 Software 2 11-24-2003 09:48 AM
