Old 05-25-2012, 07:22 PM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 268
S-W-ATH maxsurf model problem
Hi,
i am trying to build a model with rhino + maxsurf, but i dont understand why i am getting Cp and Cb of this model above 1. anyone can please correct me?
Regards.
Edit: had to remove attachment
DAre To DreAm
Old 05-26-2012, 05:07 AM
TANSL TANSL is offline
Rep: 119 Posts: 475
Originally Posted by zeroname View Post
Hi,
Regards.
May attached figure give you a valid answer?
Old 05-26-2012, 06:42 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 268
yes.. so you want to say in the software they did mistake calculation? because in maxsurf i dont need to define breadth size, they take it automatically... or you can tell me in maxsurf what should i change ?
DAre To DreAm
Old 05-26-2012, 07:10 AM
Rep: 119 Posts: 475
The Cb or Cp, as used in normal calculations, are intended for single hull vessels. So we are surprised that a Cb can be greater than 1. But a value greater than 1, for multihulls, is not a bug. Maxsurf, in my opinion, is calculating correctly.
I do not remember exactly but is possible that Maxsurf lets you choose how it has to measure the beam.
Old 05-26-2012, 07:23 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 268
Yes , there is option for selecting is it monohull or multihull. and also symmetric or not ... i was worried because of getting similar Swath reference data having Cb , cp below 1
DAre To DreAm
Old 05-27-2012, 01:31 AM
bhnautika bhnautika is offline
Rep: 566 Posts: 602
Zeroname have a look at the equations for Cp and Cb and the relationship between LWL and area and volume.
Old 05-27-2012, 06:33 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 268
In the attachment you can see , the calculation forumla resulting values below 1. but when i set the hull type as :catamaran in maxsurf, it goes above 1 . and i am even not sure the formula they used for Cb , Cp is will be correct.
Because TANSL's picture formula will result Cb around .712 which is more logical.
DAre To DreAm
Old 05-27-2012, 09:27 AM
Rep: 566 Posts: 602
Zeroname are you trying to calculate for one hull or both. The figures for Beam at wl is across the whole rather than just one and the same for the max cross section. For the Cb wouldn’t the max beam of a hull be better than the WLBeam (of one hull) as at that point its not a very good representation of the width of that hull . I did a quick calculation based on hull width and got a Cb in the 60’s. The Cp looks reasonable given the hull shape.
Old 05-27-2012, 09:58 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 268
I set in maxsurf as Both the hull is symmetric. and Vessel type : Catamaran , putting the centre distance of demihull : 11m .
can you just tell me what things i should change in maxsurf?
is your result .60's comes using maxsurf or other tools?
DAre To DreAm
Old 05-27-2012, 11:50 AM
Rep: 119 Posts: 475
You can use the beam that you want but, depending on what calculations, you need to use one or another value for Cb, always thinking about for what are you using this value. If, for example, you need a power-speed prediction you should use a Cb>1.
See attache what is in HydroMax Manual
Old 05-27-2012, 12:40 PM
smartbight smartbight is offline
Naval Architect
Rep: 55 Posts: 102
Cp and Cb of this model < 1
Hi,
Regards.
Take a look at Delftship output.
S-W-ATH maxsurf model problem-hydrosswath0.png  S-W-ATH maxsurf model problem-hydrosswath1.png  S-W-ATH maxsurf model problem-hydrosswath3.png
Old 05-27-2012, 01:35 PM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 268
SmartBight, can u check my model with Delftship ? i am not good at that tools. at DWL =6
DAre To DreAm
Old 05-27-2012, 05:50 PM
Naval Architect
Rep: 55 Posts: 102
Delftship does not read your Maxsurf, ***.msd directly. If you can export your .msd to an IGES format, ****.igs or ***.iges and post it; we could give it a try.
Old 05-27-2012, 07:52 PM
Rep: 566 Posts: 602
Zeroname if you look at the output supplied by smartbight the Cb is close to what you got even with a different design. This is I believe because both programmes are using the same BWL position. Look at the three examples, all fit the equation in the calculation sheet (V/L*maxb*maxd). The first one is the one being used in your calculations based on the figures. It comes down to, does the trad ional fit the unusual.
Old 05-28-2012, 12:30 AM
Naval Architect
Rep: 55 Posts: 102
Ran it on GHS. No time to check output.
Check it yourself !
Maxsurf problem ! japix Software 11 01-23-2009 08:18 AM
Maxsurf Problem duraeps Software 11 01-04-2009 10:33 AM
a maxsurf problem pavel915 Software 2 12-30-2006 03:16 AM
A Problem in Maxsurf bhabanism Software 2 09-01-2006 12:22 PM
a problem with maxsurf? zhmeww Software 0 04-22-2004 04:44 AM
