Old 07-16-2010, 09:34 AM
Epoxus Epoxus is offline
Rhinomarine: multihull hydrostatics
Hi guys,
I'm trying to get GZ righting arm curves from Rhinomarine for a multihull vessel. For simplicity I have just drawn 2 rectangular closed volumes and subsequently meshed these.
No when I compute the hydrostatics for heel angles 0,10,20,30,40,50,60,70,80,90 it fails with the error:
'Failed to compute rollover hydrostatics. Check you surface normal directions and make sure that all 'open' surface edges do not become submerged during heeled hydrostatics...'
If I decrease the heeling angles (<15 degrees in my case) to the point where one of the decks is not yet submerged it does run the calculation. However I would like to have the curve to at least the point of vanishing stability. I did check the normal surface directions and these are all ok. Also the hulls are fully closed. Does anyone have a suggestion on how to solve this? Thanks.
Rhinomarine - adding keel - hydrostatics magelh Software 2 12-14-2008 11:37 AM
Tutorials Rhinomarine sandersc Software 6 01-24-2008 04:46 AM
Rhino + RhinoMarine plug-in Jan Buczek Software 1 04-23-2006 06:27 PM
New release of RhinoMarine posted BHays Software 0 02-06-2006 12:53 PM
rhinomarine Cp question samh Software 2 03-13-2005 05:05 AM
