Old 03-03-2005, 11:03 PM
samh samh is offline
Registered
Rep: 10 Posts: 38
rhinomarine Cp question
Having a bit of difficulty getting rhinomarine to produce a prismatic coefficient. I have sections set up for the model, so thats not it. The hull is lofted surfaces, as in a hard chined sailboat hull. I did 'join' them, but that doesn't seem to make a difference.
SamH
Old 03-04-2005, 12:18 AM
Registered
Rep: 10 Posts: 38
seems to have been sorted by setting surface normal direction..
sh
Old 03-13-2005, 06:05 AM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
I don't use Rhino marine but you may want to cross-check the answer. You need the following bits of information....
The immersed midship section area (Am)
The waterline length (L)
The immersed hull volume (V)
Cp = V / ( Am*L )
the Cp SHOULD be less than 1. in the case of a simple cuboid barge it will be 1.
You can find all the data required from the geometry.
Good luck,
Tim B.
Hull enlargement question?? jackason Boat Design 3 09-09-2005 08:03 PM
Fiberglass Hull Liner Question Seadog Fiberglass and Composite Boat Building 7 08-14-2005 07:42 PM
Introduction and a Question AndyC Open Discussion: All Things Boats & Boating 16 07-13-2005 05:44 AM
I/O to Inboard Conversion; DWL Question MDuff Powerboats 7 11-23-2004 05:04 AM
Planing hull question graham Boat Design 10 12-13-2001 05:40 PM
