| Rhinoceros (About unrolling commands) Hi everyone; I am trying to nest a sailing boat's deck plates and shell expansion plates. There is non-developable plates (curves in 3 dimensions) So which command is more useful than other? I guess there is three options : Unroll, Smash and squish ? |
| material of sailing boat is aluminium. |
| Squish http://docs.mcneel.com/rhino/5/help/...nds/squish.htm UnRollSrf http://docs.mcneel.com/rhino/5/help/.../unrollsrf.htm Smash http://docs.mcneel.com/rhino/5/help/...ands/smash.htm McNeel recommends using Squish rather than Smash. Squish is newer and provides more controls including how the surface will distort when it flattens. Also Squish has the associated SquishBack and SquishInfo commands. From McNeel's website: http://wiki.mcneel.com/labs/advancedflattening Rhino 4.0 has:Experiment. Try flattening the same surface using the different commands, and different settings within Squish.
__________________ David Cockey |
| Thank you for answer David. In your opininon, which one is more safe while nesting aluminium plates ? I am scaring in case plates wont fit. |
| This is deck plates of my sailing. And ı squished some plates. Do you think that this is true? |
| What method will be used to make the flat plates conform to the compound curvature surface?
| ı used "squish" command. Was this answer of your question? Maybe ı underdtand wrong your question. |
| When the boat is actually built from aluminum, how will the flat aluminum plates be formed so that they conform to the compound surface?
| It should be very simple... Before "Squishing" just divide the surface according to the plate distribution you want using "Split" command... Then go for squish.... the plate will be of course fitted nicely... I did it practically by myself...
__________________ Md. Al-Amin Pavel http://www.paveldesign.tk "A question that sometimes drives me hazy, am i or are the others crazy?" Albert Einstein |
| Yacht design in Rhinoceros 4 | marinavaleng | Software | 33 | 04-07-2011 11:59 PM |
| Rhinoceros | sunadria | Boat Design | 6 | 03-27-2010 01:27 AM |
| Hull Modeling With Rhinoceros | Antisthenes | Software | 14 | 08-08-2008 04:41 PM |
| GHS Macro Commands? | GhrarhG | Software | 8 | 02-13-2006 05:41 PM |
| Hydrostatics in Rhinoceros | Software | 10 | 06-24-2002 02:27 AM | |
