Old 06-26-2007, 03:29 AM
AlexDim AlexDim is offline
Rep: 10 Posts: 7
Rhino - Triangulate 3d points?
Hello. I have a dxf file consisting of points describing a ship hull. (attached).
Is there a way I can triangulate these points in Rhino? My goal is to save out
a file where the hull is saved as a list of triangles.
Please help. thank you
Alex from norway
Old 06-26-2007, 05:47 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
Take your DXF definition, generate a 3D hull surface, export as raw triangles.
Tim B.
Old 06-26-2007, 06:02 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
You could alos look at the Terrain plugin from Sycode.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 06-26-2007, 06:05 AM
Rep: 10 Posts: 7
Thanks for quick answer. Is there a simple/quick way to generate the 3d hull surface? I might have to do this on several different files and time is essential. I have looked at lofting, but get problems with the bulb..Is this the right way to go?
thanks again.
Old 06-26-2007, 06:07 AM
Rep: 10 Posts: 7
I have tried the terrain plugin, but is seems to create problems at the bulb..
Old 06-26-2007, 06:48 AM
Rep: 10 Posts: 7
Reduce triangles?
I got the hull into triangles, is there a way to reduce the number of triangles?
thank you
Old 06-26-2007, 03:09 PM
You can use several algorithms once you've got the triangles, but it's easier for everyday work to change the advanced settings when you export in Rhino.
Tim B.
Old 06-26-2007, 04:03 PM
Steve Baer Steve Baer is offline
Rhino Developer
Rep: 64 Posts: 90
Is there a specific file format that you are trying to write to? Do you need triangles for rapid prototyping or analysis or something else? Your DXF file looks like you could put some surfaces together pretty quick using lofts, sweeps, and patches. Once you have actual surfaces (not meshes), you can tweak Rhino's mesh settings to get the triangle mesh you want.
Thanks,
-Steve
Old 07-02-2007, 05:42 AM
Raggi_Thor's Avatar
I think you r question now is "how to model the hull from those dxf lines" :-)
Here is one method,
http://www.rhinocentre.nl/pdf_bestan...Rhinoceros.pdf
An other method would be to make the parallel midship as long as possible, then model the bow and merge and match a surface between, then the same in the aft, but maybe with more surfaces because if the propeller housing.
Anyway you choose, the first step is to make new curves, as smooth as possible with as few control points as possible, but as close as you need to the original dxf.
www.MBOATS.no
Old 07-03-2007, 10:16 AM
Rep: 10 Posts: 7
thank you
Old 07-03-2007, 04:57 PM
Raggi_Thor's Avatar
Alex, snakker du norsk?
www.MBOATS.no
Old 07-04-2007, 07:47 AM
Rep: 10 Posts: 7
jada, her snakkes det norsk
Mounting 'rep' points Bergalia Open Discussion: All Things Boats & Boating 15 06-07-2007 06:15 PM
Burnt Points FISHERMAN1 Electrical Systems 8 06-04-2007 07:13 AM
Fitting a Curve to Offsets Points in Rhino CET Software 6 01-04-2006 08:31 AM
points cloud Mirko Software 10 06-25-2005 06:59 AM
Joining points in Prosurf Willallison Software 2 09-09-2002 05:49 PM
