Old 11-16-2011, 04:44 PM
JordieS JordieS is offline
Rep: 26 Posts: 89
Rhino surface lumps
Hi everyone,
Just have a question regarding rhino, how do you get rid of these lumps and make a smooth surface?
See attached images.
I have highlighted the lines I am using as my cross section lines using the Sweep2 command.
Old 11-16-2011, 09:01 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
A number of possibilities:
  1. Use degree 3 curves if you are are using higher degree curves.
  2. Use fewer sections.
  3. Use the NetworkSrf command instead of Sweep2
  4. Modify the sections.
  5. Add some "diagonals" which intersect the sections. The combination of sections and diagonals will probably needto be adjusted so all curves are fair. Then use NetworkSrf to create the surface.
  6. Try the Patch command to create the surface though it probably won't help.
I use the fewest number of curves with the least number of control points on each curve necessary to create the surface I want.
David Cockey
Old 11-16-2011, 09:34 PM
Rep: 26 Posts: 89
NetworkSrf worked like a dream, thank you so much
Rhino Rhino Rhino (hull thickness, offset surface, and unrolldvp for cnc cutting) metin_mehel Software 11 10-11-2011 12:10 AM
Rhino - calculating the surface Maciej Software 7 06-07-2005 01:01 AM
Use Rhino to create surface between stations? ivansalasj Software 9 01-18-2005 04:08 AM
hull surface at rhino gunther prien Software 1 08-03-2004 10:32 AM
Surface thickness - in Rhino Willallison Software 6 11-30-2003 04:34 PM
