| Rhino sectioning problem I made a knuckle point in a surface by compacting 3 control points. But after doing that I can take any section in that surface. How can i solve this problem???(the file and screenshot are attached)
__________________ Md. Al-Amin Pavel http://www.paveldesign.tk "A question that sometimes drives me hazy, am i or are the others crazy?" Albert Einstein |
| I did something like, create a new curve using extract wireframe and created a new surface from curve network. I attached a file with a good surface |
| I have had a few problems with RH4 taking sections, though these seem un-related and have been solved in RH5 (WIP). The better way to create a knuckle is to change the control point weight, rather than putting several control points at the same location. Hope this is of some help. Tim B.
| Thanks a lot Tim B,,,, Your idea about control point weight to create knuckle point was great. I attached the modified surface (Rhino File)
| Rhino problem | zeroname | Software | 2 | 06-02-2010 10:56 AM |
| 2D Rhino to Autocad export and rhino sectioning | fede | Software | 13 | 10-18-2009 02:55 AM |
| Rhino rendering problem | ct marine nz | Software | 5 | 06-06-2008 01:15 AM |
| trimming problem in rhino | fede | Software | 4 | 06-12-2005 03:53 AM |
