Old 05-15-2005, 09:46 PM
ARGO ARGO is offline
Rep: 10 Posts: 15
Rhino render
This has to do with rendering out curved surfaces. When it renders out , the edges looks like polylines. The contours form poly edges.
This happens after i get further into the construction.
I have fixed this problem before, i was wondering if anyone had a good fix for this problem.
Jason
Old 05-16-2005, 12:12 AM
RThompson RThompson is offline
Rep: 106 Posts: 133
Hi Jason,
Maybe the render mesh is not fine enough.
go to:
"document properties", then "mesh"
tick the box for "smooth and slower"
If the renders are still not good enough, then tick the custom box.
Leave all the settings the same except "minimum initial grid quads" - set that to 200. (I have found that to be the fastest/simplest way to refine a render mesh more than the defaults)
Rob
Old 05-16-2005, 09:36 AM
JEM JEM is offline
Rep: 38 Posts: 291
You might want to switch to the treefrog rendering option. Gives smoother lines and quicker. Also look in your document properties and click on the mesh option. Adjust those settings.
Even if your surfaces are fair and smooth, it's the display that is making it look funky. Rhino does this to save memory and speed. The finer display you have, the more memory it takes up.
I often create a separate file just for rendering a design. I leave out all the internal framing that can't be seen from the outside anyway. This keeps the file memory size low. If you don't have at least a Pentium 3 (or equivilant) and 128 of RAM, you'll be waiting a while for more complex images to render.
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 03:55 AM
Rhino <-> AutoCAD conversation Tobias Software 3 08-14-2004 12:34 PM
Rhino Newbie Act Too... jprev Software 17 02-19-2004 01:30 PM
Fairing in Rhino shu Software 13 01-06-2004 10:38 AM
Rhino blewett_john Software 29 01-18-2003 06:05 AM
