Old 11-16-2008, 07:39 PM
CET CET is offline
Rep: 10 Posts: 114
Rhino Question about Control Points and Degrees
Are there rules or guidelines for how many degrees to use relative to the number of control points when rebuilding a curve or surface? I know the fewer the control points, the more fair the curve or surface is likely to be, but the number of degrees is something I don’t understand. Any help appreciated!
Old 11-17-2008, 12:24 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
degree of curvature of curve is n+1, where n is the number of maximum and minimum point( chrest and trough) it have.
If the curve represensts a polynomial; degre is the highest power of "x" it have. As example if the equation of curve is x^3+x^2+2x+6=0 then the degree of the curve is said to be 3.
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 11-17-2008, 09:49 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 262
for better understand, draw a simple curve , choose different degree and click preview , try it several time.. u can easily understand whats going on..
and pavel just say exactly that is written in the help file... so read help file to know more.. its simple
thanks
Old 11-19-2008, 03:00 PM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
Usually a degree of 3 is enough for a fair surface. A higher degree is possible and often yield in smoother looking surfaces. On the other hand the area of influence of a control point is larger. This can be seen very well while drawing a curve. If you have a curve of degree 3 and move one of the control points the part of the curve that actually changes maximally has the length of 4 controlpoints, two on either side of the point you are moving. If you use a curve of degree 5 this length increases to 3 points on either side. This is the area of influence of a control point.
While modeling surfaces the same occurs, only this time in two directions. The larger this area of influence becomes the harder it gets to fair it.
Old 11-19-2008, 06:13 PM
CET CET is offline
Rep: 10 Posts: 114
Your explanation makes perfect sense. THANK YOU!!!
CONTROL POINTS in Rhino Marine... Sean Herron Software 0 11-11-2007 09:36 PM
RHino question jmedick Software 2 07-31-2007 06:04 PM
Rhino - Triangulate 3d points? AlexDim Software 11 07-04-2007 07:47 AM
Moving multiple control points in FreeShip SeaSpark Software 4 06-15-2006 06:02 AM
Fitting a Curve to Offsets Points in Rhino CET Software 6 01-04-2006 08:31 AM
