Old 11-13-2010, 07:02 AM
jollyricard jollyricard is offline
Rep: 10 Posts: 73
rhino question
i have a model 3d in rhino;
HOW i do to change the surfaces in rhinoceros? i want modify them in affinity....
Old 11-13-2010, 07:24 AM
whoever's Avatar
whoever whoever is offline
Rep: 10 Posts: 5
Select the surface u want to change and edit>change object layer(choose 1 layer) and then choose the layer what u select before.there is a lot of options like material library,linetype etc. so u can change the options and modify the layer
Old 11-14-2010, 05:23 AM
bhnautika bhnautika is offline
Rep: 566 Posts: 601
Jollyricard if you want to change the shape of a surface there are a number of ways to do this. Once you have selected the surface you want to change go to ..edit > control points > control points on (F10). You can then move the points around to change the shape. You can also add more control points using the ..Insert control point or Insert knot command. You can also use the .. Edit weight for individual control points to change the shape in the localised area of that control point. Then there is .. Rebuild and Change degree which are similar to adding control points but in a different way and enable you to put sharp edges. Hope this is what you are after.
Old 11-14-2010, 08:21 AM
Rep: 10 Posts: 73
thanks for answer;
i want to create a hull greater of.....tot, this is my question; i have already the model 3d;
Old 11-14-2010, 05:20 PM
Rep: 566 Posts: 601
Jollyricard I assume tot stand for total so are we talking about scaling. In the menu.. Transform there are four scaling methods, 3d that as the name implies changes the size in the three dimensions. 2d, length and width but not the depth of the object in the “active” view and 1d which only changes the object in the direction that you choose in the “active” window.The non-uniform is the same as 1d but in a 3d sequence
Old 11-15-2010, 03:42 PM
Rep: 10 Posts: 73
thanks, this was my questions; i solved the problem;
thanks
Rhino Gaussian Curvature / Developable Surface Question info@mds.org.nz Software 5 08-13-2010 11:08 AM
Rhino Question about Control Points and Degrees CET Software 4 11-19-2008 07:13 PM
Rhino Surface creation question Arvy Software 3 08-15-2007 06:47 AM
RHino question jmedick Software 2 07-31-2007 07:04 PM
software design question for Rhino Newbie pdavidson Software 8 02-28-2005 12:04 AM
