| Rhino Query Can Rhino directly import offset table values and create the lines by itself?which software is best for this purpose?I heard Delftship can do it. |
| as far as i know.. u have to set point according to offset table values , then using curve need to draw lines .. delftship , model maker , or other can do only if ur offset table is in acceptable format .. |
| To paraphrase from another forum: Rhino can import offsets in a number of formats. Points can be imported from a .txt file, for example. Here is an excerpt from the Rhino Help file: To open or import a point file: 1. From the File menu, click Open or Import. 2. In the dialog box, in the Files of type box, select Points File (*.asc; *.csv; *.txt; *.xyz). 3. In the File name box, type a name for the file. 4. Click Open. 5. In the Points File Import Options dialog box, select the delimiter character and specify whether to create a point cloud object from the file. 6. Click OK. Note: Point files must be in the form: x,y,z with no additional heading information at the top. The characters can be separated with a variety of characters and can be surrounded by quotation marks. Also, remember that Rhino can also import DXF and IGES files with polylines. While it currently does not have a function to fit a candidate surface to a set of points, it does have the ability to "loft" surfaces through curve networks as well as to evaluate the deviation between a set of points and a surface. ----------- It will not create curves from these points but you can use an interpolated curve and snap from point to point. Joe Last edited by Joe Petrich : 04-02-2009 at 02:19 PM. Reason: additional thought |
| there is a plug-in for rhino can do this work,but i forgot the name ,you can search for it |
| i need one info,. about rhino suppose, i want to use a picture as a label of a bottle, how can i set the picture on the body of the bottle? which command? thanks |
| you can project a square on to the bottle to represent the label and then split the surface using the square...then go to properties....material....basic...texture..and select the bitmap you want to use as a label |
We have done this easily based on a csv (comma separated variable) export from excel and then add the CAD commands to that data with a text editor. It's quite interesting to watch all the lines being drawn. Cheers
| Can you explain this more for me Cheers |
| Quote: do u have any script for this? thanks |
| Steel Welding query | JimCooper | Metal Boat Building | 23 | 08-13-2009 02:46 AM |
| Query abt Concept | amateur mariner | Boat Design | 2 | 02-26-2009 11:13 AM |
| material query | amateur mariner | Materials | 6 | 02-11-2009 05:04 PM |
| deck beams query | lazeyjack | Software | 2 | 04-15-2007 05:41 PM |
| Engine query | olley8 | Powerboats | 4 | 01-15-2005 05:29 AM |
