I've had some success with running curves through divided transverse curves. I wasn't aware of the InterCrvOnSrf command.... I have tried projecting onto the surface, but have found you can get some peculiar results of the surface has much curvature in more than one plane. Extruding the curve and then intersecting met with more success - as long as you extrude in the right directions... But I'll definitely give that one a try... thanks I'll also try the OffsetCrvOnSrf command too - thanks TH ![]() ![]()
| Stiffeners spacing | DUCRUY Jacques | Class Societies | 2 | 08-22-2010 06:56 PM |
| How to get flat bottom panel plate development...? | Elmo | Software | 1 | 06-10-2010 10:09 PM |
| Transverse/Primary Stiffeners | CanuckGuy | Boat Design | 2 | 12-22-2009 08:17 AM |
| BHD stiffeners | ringoo83 | Boat Design | 5 | 02-24-2009 04:52 PM |
| Rhino and Bottom longs | 3dig | Software | 2 | 05-08-2005 10:33 AM |
