Old 09-30-2003, 12:14 PM
henrikb's Avatar
henrikb henrikb is offline
Rep: 116 Posts: 112
Rhino lofting newbie...
Hi all!
I am playing around with rhino trying to loft a hull.
When lofting with "tight" setting, the surface does not follow the guide curves (it only does when I use the "straight sections" setting). Is this beacuse of that the hull/guide curves are not fair enough?? Or do I have to put some sections before the actual hull starts?
Any hints please!?
Best regards!
/Henrik
Old 09-30-2003, 12:55 PM
ErikG's Avatar
ErikG ErikG is offline
Rep: 339 Posts: 397
Hej Henrik
I'll take it in english for the rest :-)
There used to be a basic tutorial for marine lofting in Rhino, I think it used to be available throgh the Rhino website, but it's not there anymore.
Does anyone know where to find it?
But I've had ok results with the simple shapes I've done in Rhino. For Hulls I use other sw.
Lycka til
ErikG
Old 09-30-2003, 01:50 PM
henrikb's Avatar
Rep: 116 Posts: 112
Distorsion of some kind...?
Seems like there is some sort of distortion that comes from the radii at the stem. When I loft with only one of the middle sections, stem and transom, something happens at eactly the same place with a "surface line" beginning at the radii.
Maby I should try a larger radii or cut it away after lofting??
/Henrik
Old 09-30-2003, 05:46 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Henrik,
Can you post an unshaded view so we can see the isoparms? It's a lot easier to tell what's happening from them.
Thanks,
Steve
Old 10-01-2003, 03:09 AM
henrikb's Avatar
Rep: 116 Posts: 112
Unshaded
Here is the unshaded version
Old 10-01-2003, 08:12 AM
SailDesign's Avatar
Interesting! I've never seen it do that before. You may find that re-defining your section curves with the same number of evenly-spaced points will reduce that. Rhino can do this for you (Curve, Edit Tools, Rebuild), relatively accurately for this kind of application.
Steve
Old 10-01-2003, 11:45 AM
Hans Friedel Hans Friedel is offline
Rep: 10 Posts: 115
Den har snott sig
It is twisted
Rhino is very fussy about how you click on the curves. Try to click on the curves in a similar way. It also helpes if the curves have similar points and degres.
Hör av dig om det krånglar
Hans Friedel
Old 10-04-2003, 05:36 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
Yep, Rhino is fussy about the clics, - make sure you click the curves at the same place on each one.
You might also try sweep along 2 rails using the sheer and CL. rather than loft
Paul
Old 10-05-2003, 02:36 PM
SailDesign's Avatar
Polarity has a point there. You might also want to try "Surface from Curve Network", which has worked wonders for me when all else fails (yes, it happens frequently...)
Pic below has at least one surf created with each method, IIRC.
Steve
newbie - Rhino - table of offsets pdavidson Software 6 08-29-2005 12:38 PM
software design question for Rhino Newbie pdavidson Software 8 02-28-2005 12:04 AM
Rhino <-> AutoCAD conversation Tobias Software 3 08-14-2004 12:34 PM
Rhino Newbie Act Too... jprev Software 17 02-19-2004 01:30 PM
Fairing in Rhino shu Software 13 01-06-2004 10:38 AM
