| Rhino hydrostaticts I am wrestling with the hydostatics in Rhino. I have "built" a design I did 10 years ago and have built and sailed a lot so I know the data well. Having "built" it in Rhino all displacement figures fits very well but when I try to run the hydrostatics with input from the weight calculator the boat end up floating bow down more than 45 dgr. Anybody out there with experience from this tool. I think I have followed the instructions in the hydrostatics help but obviously I am doing something wrong. |
| Hummm.... Perhaps check where you are from zero....the boat may be positioned on the negative side rather than the positive?
| Thanks, I had the boat on the negative side with the zero at the forward end of the waterline. I moved it so the aft part of the transom is now at zero and the boat is on the positive side and now it all comes out right but when I ask to have the boat in the correct floatation position it moves aft till it has the zero point about midways?????????????? |
| So you are using rhino-marine. If it ends up trimming down by 45 degrees your weights and moments are out. Check that your upright CG matches your CB for a start.
| 2D Rhino to Autocad export and rhino sectioning | fede | Software | 13 | 10-18-2009 02:55 AM |
| rhino help | snow 57 | Software | 2 | 09-04-2007 04:57 PM |
| Need some help on RHINO | Barbaros | Boat Design | 6 | 08-07-2007 11:19 AM |
| anybody help me for rhino | mechatics | Software | 18 | 09-25-2005 08:22 PM |
| Rhino help | Vibtor | Software | 2 | 04-15-2005 05:34 PM |
