Old 04-15-2005, 02:36 PM
Vibtor Vibtor is offline
Rep: 10 Posts: 10
Rhino help
Im working with Rhino 3.0 and Flamingo.
How can i "paint" a ships hull in different colours ?
Ex: I want to have different color for the antifouling and the upper ship
hull.
Best reg:
Torkild Skjong
Maritme Partner As
Old 04-15-2005, 03:44 PM
Navaldesign Navaldesign is offline
Dr. Eng.
Rep: 10 Posts: 15
Duplicate the surface "IN PLACE"
Then trim the two surfaces with an horizontal line placed at the height of the antifouling line. Of course you must trim the upper part of one surface and the lower one of the second surface.Then color the two trimmed surfaces with different colors.
Alternatively create different surfaces for the upper and lower parts of the hull.
Navaldesign
www.navaldesign.it
Old 04-15-2005, 06:34 PM
CGN CGN is offline
Rep: 121 Posts: 547
Save a copy of the hull that you want to use for rendering and use the "split" tool to "cut" the stripes, i hope the video can help, if you don't own flamingo then this way can be used, the best way is to have a render software and use texturing, but the trick works really good anyway.
the video shows only the use of the "split" tool and instead of a hull it shows an sphere.
good luck
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 03:55 AM
Surface modeller and hydrodynamics Jaakko Boat Design 13 01-07-2005 07:21 PM
Rhino <-> AutoCAD conversation Tobias Software 3 08-14-2004 12:34 PM
Rhino Newbie Act Too... jprev Software 17 02-19-2004 01:30 PM
Fairing in Rhino shu Software 13 01-06-2004 10:38 AM
