| Rhino/Flamingo rendering help ! I use Rhino/Flamingo for boat designing. Is there any way to make a total transparent background when rendering ? |
| The big question here is - what's on the other side of a transparent background? You could try just having a background image... |
| Rhino/Flamigo rendering help. I use to copy the rendered images into Photoshop. Then i do not want any background at all. Now i have the problem that a squared "solid" background follows the image and covers other images on the same "sheet". best reg: Vibtor |
| With a solid background you should be able to select it with the magic wand tool in photoshop and make it transparent there. |
| Go into Flamingo "environment" settings dialogue box. put a tick in the "alpha channel" box. now once you have rendered the image you can select he background in photoshop using the alpha channel. look under flamingo and/or photoshop help for more info on exactly how to do it. (its well worth the five minutes it takes to learn about using alpha channel). Good luck, Rob |
| make sure to save the rendering as a tiff, though, to use the alpha channel. |
| Photoshop will do magic on your rederings.
__________________ Jason |
| Affordable good rendering software | Johan | Software | 3 | 03-12-2005 10:28 PM |
| Quality modelmaking and 3D rendering services | john k | Services & Employment | 0 | 09-24-2004 03:25 PM |
| Rendering in MaxSurf???????? | Soeren R | Software | 9 | 03-23-2004 10:31 AM |
| Rendering tools??? | Hans Friedel | Software | 4 | 10-11-2003 01:09 AM |
| 3d rendering of original boat project | Guest | Services & Employment | 0 | 08-06-2003 09:02 AM |
