Old 06-04-2005, 08:53 AM
Maciej Maciej is offline
Rep: 10 Posts: 52
Rhino - calculating the surface
Hi,
I am quite fresh in Rhino but still learning.
How can I calculate surface area in Rhino ? eg. there are bulkheads in the hull and I would like to calculate surface in m2 for eg material estimation ?
thanks for help
maciek
Old 06-04-2005, 10:13 AM
CGN CGN is offline
Rep: 138 Posts: 547
Type on the command line "Area", then select the surfaces you want to know the area.
now, for weight of a bulkhead (as example) at least on V2 there is no way to set a density, so you need to use a calculator or spreadsheet to calculate weight.
Area (from Rhino) x Thickness x Density of material= Weight
or...
Area (from Rhino) x Wt per Sqr m of the material = Weight
or...
Convert the Area into a solid
Volume (From Rhino) x Density = Weight
Old 06-05-2005, 05:35 AM
Rep: 10 Posts: 52
Thanks very much!
Also I wouldlike to make workshop drawings from Rhino. More or less I know how to make this.
When I make dimensions in Rhino digits are very small (invisible) if i scale it (bulkhead 2,2mx1.8m) eg. 1:20. Do you think it wil be better to export several elements to eg. Acad?
thanks
Maciej
Old 06-05-2005, 12:29 PM
CGN CGN is offline
Rep: 138 Posts: 547
I prefer to export the sections form rhino to any CAD program and add dimensions there, I find it easier and friendlier than rhino, but if you like to use Rhino for 2D and dimensioning then follow this to setup your dimensions:
Dimensions>Properties....in the new screen play with the scale. see attached image
Old 06-06-2005, 03:58 AM
Rep: 10 Posts: 52
ThThank you, I very appreciate your help.
I will export to AutoCad. I made as dxf but there are some options. Which are most proper to save in Autocad?
Thank you once again.
Maciej
Old 06-06-2005, 03:28 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Unless you're using really fancy specialized tools, all the AutoCAD formats work. Default DWG format is what I usually use; DXF is more for compatibility with third-party stuff in the newer autocad versions. Just be sure when exporting from rhino to use splines, not polylines, to get exact curves.
Old 06-06-2005, 03:35 PM
CGN CGN is offline
Rep: 138 Posts: 547
Rhino Export
Hi Maciej,
If your units are mm, then to export DWG or DXF use the settings as per the attached images, that will create a polyline with a tolerance of 1/2 mm (from the spline in rhino with the polyline created for DWG or DXF).
Also spline>projected to plane - setting works fine.
I use the spline option because I get a clean line instead of multiple segments like the polylines, but both ways are functional.
Rhino - calculating the surface-rho_settings_dwg_or_dxf.jpg  Rhino - calculating the surface-spline_to_polyline.jpg
Old 06-07-2005, 01:01 AM
Rep: 10 Posts: 52
Thanks
Maciej
iges trimmed surface problem in maxsurf hasicktear Software 16 02-13-2006 11:25 AM
Use Rhino to create surface between stations? ivansalasj Software 9 01-18-2005 04:08 AM
Transform 2D plan into 3D object Archive Software 19 08-18-2004 09:42 PM
hull surface at rhino gunther prien Software 1 08-03-2004 10:32 AM
Surface thickness - in Rhino Willallison Software 6 11-30-2003 04:34 PM
