| Rhino and Bottom longs Hello! I am in need of a way to extrude a line that has been imbedded into a surface, perpendicular to said surface, throughout the line length. I am trying to create, both visually, and physically, logitudenal stiffening along a curved bottom plate. I need the "long" to extend vertically 90deg from the bottom at all times. anyone have experience with this issue? Ive established a workaround, but it isnt as accurate as Id like. Thanks in advance. |
| Get the bonus tools. There is a command call extrude curve normal to surface. I suspect this is the command your looking for. Also, you could make two lines on the surface and a profile shape and extrude along two curves. Good luck with it. |
| assuming you want the top of the stringer parralell to the hull offset the hull surface inwards. use the surface normal in the lines menu, draw a few lines where you want the edges of the stringer, loft these curves to produce two surfaces parralell to each other but normal to the hull, then trim these surfaces until you have a top and two sides. Generally, it is nice if stringers follow isoparms as much as possible. Have fun, Tim B.
| Quick hull in Rhino | Polarity | Software | 22 | 02-09-2008 11:49 AM |
| Longitudinal stringers or Transverse ribs for flat bottom | dick stave | Boat Design | 1 | 02-13-2005 08:03 AM |
| Round chine hulls in Rhino | shu | Software | 4 | 05-10-2004 02:16 PM |
| Surface thickness - in Rhino | Willallison | Software | 6 | 11-30-2003 05:34 PM |
