| Rhino to AutoShip i am perfect in modeling using Rehino 3d, so I made the hull in rhino but when i export it to autoship as a DFX file, the exporting procces goes well, and auroship could open the file, the problem appear when autoship start the hydrostatic calculation. it gives a wrong resultes why? what is the true method to export from rhino to autoship i need help plz |
| Hisham, Export as IGES from Rhino - it has always worked for me. Steve |
| Thanks Steve, it works but Autoship gives me all mass, Coefficients and Ratios with a negative sign (-) why? and how can i fix this problem? plez help me |
| ok.... i get the solution.. it is to easy , i have to reverse the direction of each serface its face is inboard, all surfaces should face the out board direction it works correctly |
| Good on you, Hisham. That is the way to REALLY get to understand software - try something, have it fail, and then figure out how to get around any short-comings. Steve |
| Creating frames using Rhino or other software | CET | Software | 16 | 12-09-2005 03:03 AM |
| Hull fairing software: Rhino vs. Prosurf/FastYacht | chomchan | Software | 2 | 10-18-2005 01:38 PM |
| Table of offsets from Rhino | maksic | Software | 5 | 10-12-2005 11:07 AM |
| Rhino <-> AutoCAD conversation | Tobias | Software | 3 | 08-14-2004 12:34 PM |
| Fairing in Rhino | shu | Software | 13 | 01-06-2004 10:38 AM |
