Old 08-12-2008, 11:30 PM
lyqqmxm lyqqmxm is offline
Rep: 10 Posts: 20
rhino 4.0 to maxsurf
hello all
i exported a trim surface to igs, and import it to maxsurf, but why surface becomed untrim,
thank you
Robin
Old 08-13-2008, 01:40 AM
v-p-k v-p-k is offline
Rep: 10 Posts: 7
Hi Robin!
Did you check naked edges before the export?
If there are some gaps between surfaces it might be problem to get the model working in maxsurf.
Here are some links that WILL help you :
http://www.formsys.com/maxsurf/msproducts/hydrolink
http://www.formsys.com/maxsurf/newsl...f---aug-2006#2
http://www.formsys.com/maxsurf/video...mMVBgs7Q6g1a-Q
VPK
Old 08-13-2008, 04:32 AM
Rep: 1623 Posts: 2,344
Robin
The lastest version is supposed to import trimmed surfaces, but with earlier versions the trimming info is not used and you have to either create an untrimmed surface first or trim it in Maxsurf.
As velipekka says you also need to fix any naked edges for maxsurf hydro calcs to work.
Mike Johns.
Old 08-13-2008, 06:42 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 316
I think there are some solutions if you dont have maxsurf 12 or more.
you can take sectional curves along the trimmed surface in rhino. Then delet the surface and make the new surface by lofting the curves. then to trimmed surface will not apear in maxsurf.
Old 08-16-2008, 06:52 AM
Rep: 10 Posts: 20
Thank above
my maxsurf is v11 , i think that is the key of question
Robin
Maxsurf vs Rhino which is easiest for building superstructures? yades Software 11 01-15-2010 04:13 AM
From Rhino to Maxsurf mkovac67 Software 6 04-13-2008 01:18 PM
iges from Rhino to maxsurf workshop lazeyjack Software 3 02-28-2008 06:45 PM
stability analysis by maxsurf, rhino , and archimedes! pavel915 Stability 16 08-01-2007 03:06 PM
exporting Rhino to Maxsurf HELP PLEASE! fede Software 8 04-13-2004 03:05 PM
