Old 02-01-2011, 01:32 AM
KRL KRL is offline
Rep: 10 Posts: 19
Rhino
Can anyone tell me how to go about designing the superstructure on a hull that has been exported from maxsurf as a rhino3d.
are there any tutorials around?
Thanks
Old 02-01-2011, 06:44 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 262
just learn the basic use of Rhino , then you can easily design superstructure in 3d model in Rhino.
If you have General arrangement plan of the ship in Autocad then that will be helpful for designing the superstructure taking the dimensions from there.
You will get good quality tutorials from here
http://www.rhino3d.com/tutorials.htm
and http://download.rhino3d.com/Rhino/4.0/Rhino4Training/
download Level 1 and Level 2 guide, and start !
DAre To DreAm
Old 02-01-2011, 07:27 AM
ACuttle's Avatar
ACuttle ACuttle is offline
Marine Design Engineer
Rep: 40 Posts: 85
This is very good advice, producing a superstructure model in rhino is very simple once you have an idea on the basics.
You can import and align and 2D drawings to act as guide or just work straight into 3D. My advice over method would be to start with continous sections (like deck heights) then work from there into other regions.
-Drew
Old 02-09-2011, 03:23 PM
KRL KRL is offline
Rep: 10 Posts: 19
Hey i have done a couple of tutorials in rhino and i have got the hang of it. My problems is that most tutorial start from curves while, when i import the hulll from rhino i get surfaces. How do i get curves out of the surfaces? Or do i have to convert the surface to some other form to start working on the superstructure?
Old 02-09-2011, 04:00 PM
CaptBill's Avatar
CaptBill CaptBill is offline
CaptBill
Rep: 64 Posts: 181
T-Splines is a third-party component you can download which greatly simplifies Rhino. It makes Rhino much more intuitive for non-professionals, for sure. You can download a free (save limited) trial from them.
I think the owner has actually posted her if I am correct, as a matter of fact.
Abrahams Altar FOUND
See Footage Jerusalem
http://MountoftheLORD.blogspot.com
Old 02-09-2011, 04:54 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
There are several ways to get curves, in part it depends on what curves you want. On the menu Curve > Curve from Objects opens a list of commands to obtain curves from surfaces.
Intersect is a powerful tool which creates curves and points where surfaces and/or lines intersect.
Now a question for you - what do you need the curves for? Why not build the superstructure onto the surfaces you imported?
Another question - how much experience do you have with manual drafting, traditional CAD, 3D modeling? Each tends to develop different ways of working.
Old 02-12-2011, 07:34 AM
formsys formsys is offline
formsys
Rep: 37 Posts: 73
To model a superstructure in Maxsurf you will find the curve commands useful. Sketch the key curves which define the key cross sections of the ss then use the extrude or skin commands to make surfaces from them. A similar approach can also be used in rhino.
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
Rhino help... Captain RAH Software 5 06-14-2007 11:37 AM
Rhino help Vibtor Software 2 04-15-2005 05:34 PM
Rhino duluthboats Marketplace 0 05-03-2004 10:14 AM
Rhino.... Nomad Software 2 03-17-2004 02:34 PM
