Old 05-30-2005, 12:55 PM
BillyDoc BillyDoc is offline
Rep: 266 Posts: 421
Rhino 3 to AutoCAD Mechanical Desktop 4 (XchangeWorks?)
Hi Everyone,
I have both Rhino 3 and AutoCad Mechanical Desktop 4 and would like to be able to design in Rhino and then move the file into Mechanical Desktop — but so far I have not had any luck with the data translation. The SolidWorks people claim to have produced a program that will get past this problem called XchangeWorks which they offer free if you call and talk to a salesperson. I called several weeks ago and the salesperson promised to drop the program in the mail that day, but I still haven’t received the program.
So my question is, does XchangeWorks actually work? And if it does, does anyone know where I could download a copy? I can’t seem to find it on the web, everything points back to SolidWorks — and they won’t provide it as a download. Or, does anyone know some other way to get a file from Rhino to Mechanical Desktop?
Thanks!
Bill
Old 05-30-2005, 01:24 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
MDT has a command "IgesIn" to import igs files.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 05-30-2005, 03:09 PM
CGN CGN is offline
Rep: 121 Posts: 547
Xchangeworks, works really good is basicly a lower version of solidworks, does not allows to create assemblys, but for single parts works realy good, I'm sure they will send you your copy.
Old 05-30-2005, 03:13 PM
Rep: 266 Posts: 421
Thank you Raggi_Thor
I have tried the IGESin command, and it does import a file, but it is corrupt. I get an error message like this: "Entities processed 49 (File contains 223)" and the image on the screen is a mess. And this is for a single part.
I think that my older version of MD may not be compatible with the newer Rhino, or some such thing.
Old 05-31-2005, 03:38 AM
Raggi_Thor's Avatar
Maybe you can choose an older version of Iges when you export in Rhino?
I see that you can select "MDT Surfaces" and "MDT Solids" in the export dialog.
What about STEP?
can MDt import that?
www.MBOATS.no
Old 05-31-2005, 11:05 AM
Rep: 266 Posts: 421
Thanks again, Raggi_Thor
MD version 4 doesn't import STEP files, or anyway my version doesn't. There is a STEP option on the "insert" menu, but it is grayed out. There must be some add-on that I don't have.
I have tried a bunch of IGES versions, including the MD solids, MD surfaces, MD3 solids and surfaces, even CATIA . . . and I can't seem to come up with a combination that works.
I guess I have to wait and hope that XchangeWorks shows up.
Anyway, thanks again for your kind suggestions!
Bill
Old 05-31-2005, 11:28 AM
Raggi_Thor's Avatar
Well, I hope you work it out.
Maybe you have to upgrade to Inventor :-) :-)
www.MBOATS.no
Old 06-02-2005, 08:38 AM
archnav.de's Avatar
archnav.de archnav.de is offline
Rep: 60 Posts: 208
Mechanical_Desktop is an ACIS based software (Version 4.0) not higher.
You can save Rhino-files as ACIS 4.0.
Then go to Mechanical_Desktop Insert - ACIS. That's it. Iges is always problematic.
As input into Rhino a step_file is the best. There is no ACIS import.
Up to 5MB you can use the free convertion service from Step Tools http://www.steptools.com/strepo/logi...slate%2Ecgi%3F
to convert files between STEP, ACIS, and Parasolid. Log in as anonymous.
I have attached the overall situation. If you have the model in STEP, ACIS and Parasolid without any mistakes you will have not any problem in the different CAD-systems.
Old 06-02-2005, 09:02 AM
Rep: 266 Posts: 421
It worked!!!!!
Thank you archnav, I just tried the ACIS approach and it worked!
Now I'm in business again.
Thank you, thank you, thank you!
Bill
Old 06-02-2005, 09:25 AM
Raggi_Thor's Avatar
Argh, why didn't I think of that,
Good to see that it worked out, though :-)
www.MBOATS.no
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 03:55 AM
Importing and exporting between Rhino 3.0 and Autocad 2004 Coen Software 4 03-01-2005 10:27 AM
Rhino <-> AutoCAD conversation Tobias Software 3 08-14-2004 12:34 PM
How to import solids created in AutoCAD to Rhino? Tobias Software 5 08-05-2004 12:29 PM
