Old 03-16-2011, 03:07 PM
Rep: 1758 Posts: 1,561
Originally Posted by Leo Lazauskas View Post
I've read dozens of books and chapters on turbulence and its causes over the last 25 years, but I can't remember the Lugt one specifically.
Remind me - does he devote a section or two to negative eddy viscosity flows in Nature?
Not sure what you mean by "negative eddy", but is has a lot on natural viscious mixing due to things like density layers, jet flows, and falling objects.
I've tried to find a way of introducing repeatable turbulence in a towing tank, but I suspect it's a hopeless cause.
Isn't "repeatable turbulence" an oxymoron? ....I mean if it is repeatable isn't it by definition a "vibration" no matter how long the period, i.e. a step function happens once and only once.....after that it is a periodic function....
Old 03-16-2011, 03:13 PM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
Yes it is, but I can't think of a better term for it.
Maybe turbulence within a given fixed range of intensity would have been better.
Old 03-18-2011, 12:09 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Or repeatable as far as the relevant probability statistics are concerned.
Vibrations are generally considered to repeat with one or more fixed periods/frequencies. Of course if enough frequencies are considered any reasonable continuous but random function can be approximated to the desired level of accuracy.
Old 03-18-2011, 09:41 AM
Uncertainity actually, lol
I spent a lot of time wallowing around in that tar pit trying to predict peak motions and loads in waves...I wouldn't advise it. Better to use stoichastic spectral analysis and then walk away knowing you did your best.
Old 03-18-2011, 09:45 AM
Uncertainty actually, pedantic lol
All I want is a way of producing reasonably consistent large values of the horizontal and vertical eddy viscosity in a tank.
Maybe I should use a tar pit.
Old 03-18-2011, 10:52 AM
To paraphrase Fermi "If I could have spelt better, I would have been a writer." I blame the English school system where I learned my colours.
Old 03-18-2011, 10:08 PM
Engineer
Agree. I was commenting on the theory, not what is a reasonable approach.
Planning hull resistance test in towing tank aziziyeng Boat Design 3 03-02-2011 12:57 PM
Wave resistance Javaid Hosany Boat Design 1 05-03-2008 02:17 PM
Wave making resistance Rescued Boat Design 1 05-21-2007 09:00 AM
Wave resistance weys Multihulls 19 01-19-2007 11:41 AM
wave resistance noar Software 3 03-31-2004 09:14 AM
