Old 09-16-2004, 04:08 AM
Thong Jia Rong
Recommendation software for resistance prediction??
Got any trial version of free software to predict the fishing boat resistance?
Old 09-16-2004, 04:31 AM
Rep: 66 Posts: 640
I can start giving you the theoretical lecture, but I would have to look it up too!So, here are some usefull threads that deal with hull resistance and software and what's it all about!
Hull speed
questions about wave resistance and form factor
Naval Architecture calculations
Hull Resistance
Calculation of wave resistance and potential flow.
Mathematical Q. about theoretical max boatspeed...
Good luck
Dutch Peter
Old 09-20-2004, 09:07 PM
Try:
www.cyberiad.net/michlet.htm
Thin-ship theory is generally used for hulls with a length-to-beam ratio greater than about 7, but recent work suggests that it can give good estimates for L/B as low as 4.
Old 10-08-2004, 09:26 AM
Jason S Jason S is offline
Member
Rep: 10 Posts: 2
Wolfson Unit Power Prediction Software
Please go to our website and look at our Power Prediction Software
http://www.wumtia.soton.ac.uk/software.html
Old 10-08-2004, 01:29 PM
CGN CGN is offline
Rep: 121 Posts: 547
http://www.sea-power.net/ this is good software too with many good resistance series
Old 10-09-2004, 10:41 AM
fireball fireball is offline
Rep: 10 Posts: 13
Hi Thong
What type of fishing boat resistance are you looking for? I have just finished the design of a commercial tuna fishing boat, and the resistance prediction methods changed throughout the design depending on the parameters of the vessel.
There is work done by Compton for semi-displacement fishing vessels, or more generally you may find some use in looking at Holtrop or Van Oortmerssen that will provide you with a basis.
Don't bother using any regression models that don't lie within the range of parameters that your fishing boat possesses.
Old 10-10-2004, 09:45 PM
Rep: 206 Posts: 391
The Hullspeed program has both Holtop and Van Oortmerssen methods, along with Savitsky, Fung, Latiharju and several other. It can read a hull shape directly from Maxsurf, or take numerical values as inputs.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Interior Design Software ielmazi Boat Design 9 02-25-2005 01:18 PM
Why Use Design Software Wynand N Boat Design 17 12-02-2004 03:08 PM
Hull Design software Tom.B Software 23 08-20-2004 03:41 AM
