Quick hull in Rhino
Discussion in 'Software' started by Polarity, Mar 1, 2003.
  1. Polarity
    Likes: 7, Points: 0, Legacy Rep: 148
    Polarity Senior Member
    OK Here goes!
    This sequence assumes some basic knowledge of Rhino - the Snaps, Ortho, curves etc. Almost all of the commands used here come from the standard bar on the left. A free evaluation of rhino is available here: http://www.rhino3d.com/download.htm - you get 25 saves and they dont want your age and shoe size before they let you download!
    If you download now you will get V3 which is essentially the same but looks a little sexier!
    NB: I am just a sailing Rhino addict with little design talent and only a very basic knowledge of the principals of yacht design (mostly picked up from this forum!) So my apologies if the hull in the tutorial looks to you like a bathtub ! (also sorry about the numerous speeling mistuks!)
    The sequence we are going to go through is as follows:
    plan deck shape and (in this case) straight transom
    profile of bow and hull bottom
    sheer line
    max beam line
    Rough surface
    lines plan
    editing and seam smoothing
    lofting surface
    hydrostatics
    After this you can use the basics to form a transom and if enough people like this, the next stages are deck,cockpit, keel, rudder, mast, rigging, interior.....
    The idea is a quick and dirty way to get a boat on screen using basic principals.
    Let me have feedback! and if anyone want to add more text to the pics, or another pic pm me with it and I will add it to each message in the thread (let me know which pic!).
    Have fun!
    Paul
  2. Polarity
    Plan and transom, First draw a line from 0,0,0 out to the right as a centerline! - Make sure your curves are snapped to this line (Near)
  3. Polarity
    pic 2
    "Lovely and smooth" is of course a highly technical naval engineering term....
  4. Polarity
    pic 3
    Lift the transom edge at the same time as the deck edge...
    Note that the 0 Axis line is the waterline.
  5. Polarity
    pic 4.5
  6. Polarity
    pic 4.7
  7. Polarity
    pic 5
    Create a rough hull shape at the maximum beam and the transom - ignore the bit about the extra point we will deal with it differently...
  8. Polarity
    pic 7
  9. Polarity
    pic 12 (erratic numbering I know!)
  10. Polarity
    pic 13
  11. Polarity
    pic 14
    This is a good way to get regular station lines, if you want to place them by hand dont bother with the array and project shown here, use "Extract isoparm" from the "curve from object" button, if it wants to extract the horizontal instead of the vertical change u to v or vice-versa in the command line. And make as many lines as you want.
  12. Polarity
    pic 15
  13. Polarity
    pic 16
  14. Polarity
    pic 17
  15. Polarity
    pic 17.3
