Old 10-04-2011, 05:16 AM
JordieS JordieS is offline
Rep: 26 Posts: 89
Questions about Rhino
Dear Boatdesign.net users,
I've read over the forums for a while now and decided to start designing a ~5m boat, I will probably just build a model and then if I want I will build the real thing.
I'm using Rhino to design the boat but I'm having some problems with using wirecut to cut through the deck surface for the (can't think of the term, so I shall say) area in which the driver and passengers sit.
When I try and use Wirecut to remove a section from the deck this is what happens (see picture) and it stays like that, I can't delete the weird extension thing either. I'm new to Rhino just so you all know.
Thanks.
Old 10-04-2011, 06:02 AM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
JordieS the wire cut is normally for solids so may act a little strange on surfaces. If you use the trim command with the line you are using as the out line for you cut in the top view you might have more luck.
Old 10-04-2011, 06:12 AM
Rep: 26 Posts: 89
When I go to select the object to trim (the surface) it won't select. It's impossible to cut it out, but thank you for clarifying wirecut for me.
Anyone else reading please help.
Appreciated,
JordieS
Old 10-04-2011, 06:29 AM
Rep: 26 Posts: 89
Don't worry everyone, I finally got it! Thanks bhnautika
Rep: 547 Posts: 540
JordieS a surface will not trim if there is any leakage around the ends of the line that is being used to trim the surface. Check and either extend the line past the edge or add a little extra and combine then try again. Sometimes if that doesn’t work “extrude the line down through the other surface, then use that surface to trim the other, then delete the extruded surface.
Olds 455 questions upon questions... pdswerld Gas Engines 26 07-07-2010 09:36 AM
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
Rhino Questions CET Software 23 03-19-2006 03:11 AM
Rhino + what? Willallison Software 46 08-08-2005 03:46 AM
Rhino help Vibtor Software 2 04-15-2005 05:34 PM
