Old 11-28-2009, 07:52 PM
yuyewuyuconan yuyewuyuconan is offline
Rep: 10 Posts: 35
Question about damage stability
HAlf years ago i began to use Compass(a chinese class societies' software ).I think many friends dot konw it ,but the way of the damage calculation is the same .IN compass you should putin :
Ls,ds.dp.......Lgp(center of gravity distance from ap when d=dp).Lgs.Vgp(center of gravity distance from BL when d=dp),Vgs...
dp=d0+0.6(ds-d0),
when d=dp
how can i konw Lgp&Vgp
wheather i can thing the ship is no trim Lgp=Lbp(i can get Lbp in hyd)
but the Vgp is not know ...any friends can help me ? thanks!
Old 11-29-2009, 08:13 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
I assume you have a design you're working on. But it's pretty much useless to asses the damage stability in a stage of your design where you don't know the VCG.
Are you working on probabilistic damage stability?
In that case VCG is initially calculated from a loadcase at design draught.
After the first run the GM is reduced to a minimum in a number of calculations so you carry as much cargo as possible throughout the ships life.
If your calculating deterministic damage stability the VCG is already known.
Old 12-01-2009, 05:18 AM
Rep: 10 Posts: 35
HI Martijn_vE
i am working on probabilistic stablilty.
why you think that loadcase is calculated?FOR example :a oil tanker(only carry one kind of liquide) so i only should calculate 6 loadcases(In CCS rule )
1.FLD 2.FLA 3.PLD(one team of tanks _max free surface ) 4 .PLA 5.BD 6.BA.IN these loadcases on one is d=dp ,dp is not design draft.
Old 12-01-2009, 06:34 AM
Martijn_vE's Avatar
Rep: 401 Posts: 252
It make sense to first calculate the loading conditions prior to check the probabilistic damage stability. It will give you a good indication for the initial VCG's needed for the damage stability calculations. After this initial guess you can lower or raise your VCG's depending on the attained index.
Old 12-02-2009, 08:15 AM
Rep: 10 Posts: 35
Thank you!
Probabilistic damage stability manon Stability 11 10-17-2010 06:55 PM
Damage Stability-passenger emergency evac watchkeeper Boat Design 1 11-21-2009 06:59 AM
basic software for intact/damage stability John Toner Software 13 10-20-2007 04:55 AM
Damage seaandland Sailboats 1 01-24-2007 01:26 PM
Damage seaandland Boat Design 1 01-24-2007 12:48 PM
