Old 08-29-2010, 11:06 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 262
Is ur Linesplane in autocad design file or a scan page? If it is scan page/picture go for maxsurf directly , do 3d then scale.
if it is in autocad format , then u can scale it first then go to maxsurf.
The question is u only need to scale down the Length of the vessel or no problem if Breadth and depth scale down too ?Because in Autocad if u select the Linesplane ,use the command scale and put .8851.... Enter , will scale down not only the length but also the Breadth and Depth.
If you want to keep Breadth and Depth Constant then its better to do 3D model first with 27 m ,, then go to Rhino and do the 1D scale of the model.
DAre To DreAm
Old 08-29-2010, 02:11 PM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
Originally Posted by ScarabSS View Post
I have to ask... are you being sarcastic? Seems so.
I assure you, things have been drawn out. The point is to learn the software with 3d modeling and so forth. If you have no real input than sarcastic remarks, your departure from the thread would be appreciated.
If I am wrong, I apologise.
Andy
Scarab Hoyt is one of the very helpful members and his advice is sound and genuine.
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 08-29-2010, 03:58 PM
NA me's Avatar
NA me NA me is offline
Rep: 10 Posts: 24
thx zeroname that was very helpful
Old 08-29-2010, 04:16 PM
NA me's Avatar
Rep: 10 Posts: 24
i'm manually recreating an offset table from scratch. from a A4 paper printed autocad bodyplan. what should i do with station lines that can't be read?
