Old 05-29-2009, 10:07 PM
JAK JAK is offline
Rep: 10 Posts: 4
Q: How to create a single curved surface in Rhino for Plywood planked Yacht Tender
Hi,
I am in need of some help.
I am using Rhino as an architect for some years now, so I've a certain (decent?) knowledge of it.
I am trying to draw a 11' Yacht Tender by Paul Gartside in 3D, which I'd like to then build with the help of a 3-Axis CNC router.
The boat is planked with 3 strakes of plywood, which of course can not have a compound curvature...
I can easily create a surface for the garboard, the way I usually would do, with for example "sweep 2 rails", but that's of course compound curvature...
I worked with the Rhino Marine Tutorial, but the way it describes how to loft the garboard for their skiff, didn't really help at all.
(Quote: If you have never done this, it probably won't work...)
I was able to loft a surface along a chine and the centerline (extended into negative space as per tutorial) but A) I am not able to precisely hit the stem rabbet and B) it's a compound curved surface again...
Could anybody explain to me how you'd create a garboard surface intended to be plywood / single curvature???
I really don't get it, and it drives me nuts!
Thanks!
Old 05-30-2009, 12:41 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
You might try curve network or edge curves, making sure both ends are straight. There is never a perfect solution. You have a lot of give and take, draw the surface, extract the lines, fair the lines, check them against the numbers, adjust, redraw the surface, …………………. Then you have to flatten them and check for more errors it’s frustrating and not easy to turn someone else’s design into CNC files.
Gary
"The hand feeds the mind."
Weston Farmer
Old 05-30-2009, 08:21 AM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
JAK there is a free plugin for rhino which may help its called “Developable Surface creation” and you can get it at. http://en.wiki.mcneel.com/default.as...oHomeLabs.html
Old 05-30-2009, 09:10 AM
nero nero is offline
Rep: 112 Posts: 624
JAK there is a program called TouchCAD. http://www.touchcad.com/
The how-to movies are very informative.
Old 06-01-2009, 09:42 AM
JAK JAK is offline
Rep: 10 Posts: 4
Thanks everybody for the input.
I'll look into it and try again.
Does anybody have experience with Rhino Marine?
The Hull design plug-in is $595...wonder if it is very useful?
Once again thanks.
J.
Old 06-01-2009, 01:30 PM
JAK JAK is offline
Rep: 10 Posts: 4
bhnautika,
I quickly downloaded the DevSrf tool, and it seems to work pretty nicely,
have to look in more detail at that surface, only did a 2-minute test during lunch, but I can't believe it! Looks good!
Thanks!
J.
Old 06-02-2009, 03:17 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 156
If the plans have offsets for each chine you could draw the curve of the chine in profile view and in plan view and then use Crv2View to create the 3D curves. Edgecrv or Sweep2 should create the surfaces once you have the curves.
I have not used Devsrf but if it works go for it.
RhinoMarine or Orca probably won't help much for creating a small multi-chine design but would be useful for hydrostatics. Of course since your boat has been designed by a good designer you should not need the hydros unless you drastically alter it.
Joe
create a cleaner Rhino Shape? Grant Nelson Software 3 12-26-2007 04:17 PM
Single surface deck in Freeship Dan S Software 4 09-05-2006 04:27 PM
How do I create a decent yacht design brief 2020 Boat Design 14 08-23-2006 07:57 PM
Use Rhino to create surface between stations? ivansalasj Software 9 01-18-2005 05:08 AM
single surface drive? zingaroo Surface Drives 5 01-06-2005 09:03 AM
