Old 07-23-2007, 09:14 PM
lazeyjack
pulling station sections out in rhino
anyone tell me how TO GET EACH STATION OUT IN THE OPEN So,s I can model my beams, usually I only cry HELP after several hours struggling, thanks
Old 07-23-2007, 09:30 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
You already have the station curves? And I imagine they're all sitting on the same layer, at their actual locations on the boat?
Try making a CutPlane, parallel to the station planes, through 0,0. Project your station curves to this plane and put each on a separate layer. Alternatively, mark a key point at each station and Move them all to the desired plane. If you're going to detail in Rhino you might want each on its own layer.
Old 07-23-2007, 09:31 PM
CGN CGN is offline
Rep: 138 Posts: 547
same question...you have the stations already? or you need to create sections from your surfaces?
Old 07-23-2007, 09:57 PM
lazeyjack
I have the stations in(from freeship), but if I were lofting a deck the old way I would take the deck, c/l height, subtract the sheer height, then that is crown H, then at 33.33%in a factor .8898, and 66%in, factor .5393, this gives me the heights at third and two third beam, do this at every beam, it makes one fair deck, if I was forming T sections or I ,s or angles, i would have to form each one from loft,
thanks men
Where is station A in offset table? Gramp34 Boat Design 3 07-16-2007 01:47 AM
Standard Al Sections navarch_hish Metal Boat Building 0 10-19-2006 09:52 AM
Helm Station Design for larger cruisers... Grant Nelson Boat Design 23 10-08-2006 09:14 PM
Matching Mast Sections phillip Metal Boat Building 5 04-22-2005 07:54 PM
Wing sections? tizbonbon Sailboats 10 02-21-2005 09:27 PM
