Old 02-14-2007, 02:52 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
propeller design in rhino
is there any plugin to design propeller in rhino?
please inform me if there is any.
thanks!
Old 02-14-2007, 10:23 AM
CGN CGN is offline
Rep: 138 Posts: 547
no plug in, but you can use rhino to model a propeller
Old 02-14-2007, 11:11 AM
Steve Baer Steve Baer is offline
Rhino Developer
Rep: 64 Posts: 90
PropCAD can help you with the design. You can export the geometry to programs like Rhino.
http://www.hydrocompinc.com/propcad/default.htm
Old 05-03-2007, 12:54 PM
Çemberci's Avatar
Çemberci Çemberci is offline
Rep: 133 Posts: 117
Dear
Are you close or cooperation with Propeller Casting as we
http://www.cembercidenizcilik.com/dokum/index.htm
If you give me size of propeller that you calculated.
I will draw your model as attached file.
Size of Propeller
Diametre
Pitch
Dar
Model (Attached Çemberci File)
Blade Number
Oktay Çemberci
propeller design vpkumar Props 3 09-25-2006 09:54 AM
i NEED YOUR HELP IN DESIGN PROPELLER IN NOZZEL ! mymind04 Boat Design 3 01-28-2006 12:55 PM
propeller design parameters fcfc Props 2 09-16-2004 08:49 AM
Propeller using Rhino 3D James Callier Software 2 02-13-2004 04:22 PM
Propeller using Rhino 3D James C Software 1 02-13-2004 12:55 PM
