Old 05-25-2004, 05:32 AM
dj68 dj68 is offline
Propeller calculation information.. plz
Hi!
Im hopeing that u can help me. I need information about how to calculate propellers from details of a boat? Do u know anything that i can use?
Just write what u know.. im really desperate
Old 05-25-2004, 11:07 AM
danmarine danmarine is offline
Rep: 10 Posts: 17
I am looking also...
Try looking in the boat design directory. eris propeller foundry is comprehensive and has a prop calculator, under propeller sizing.
If you are missing details as to gear ratios etc then you need the original calculations and equations for size and pitch...
Hope somebody can give us some idea.
I know its not always a good idea to second guess performance and manufacture specifications but us boat repair guys normally have to contend with tight boat owners and using products available...
good luck,
dan
Old 05-25-2004, 02:20 PM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 389 Posts: 507
Hej dj68
Gå på dit lokale bibliotek og lån Larsson & Eliasson: "Principles of Yacht Design" og/eller Kinney: "Skene's Elements of Yacht Design". Hvis de ikke har dem, så bed dem om at skaffe dem hjem, f.eks. fra Danmarks Tekniske Bibliotek.
Anf the rest of you have probably guessed that I told dj68 to visit his local library and borrow some books ;-)
Søren
Old 07-23-2004, 12:12 PM
Davor Davor is offline
Naval Arch.
Rep: 10 Posts: 41
Sea-Power
Originally Posted by dj68
Hi!
If you are naval arch or marine engineer try my software
www.sea-power.net
rgds
Davor
Old 09-03-2004, 07:11 PM
Rep: 1623 Posts: 2,344
Yes prop calcs are very important
If you want to do it yourself the best advice is:
Read a book by Dave Gerr called "the propellor handbook"
Cheers
Mike Johns.
Old 09-03-2004, 08:09 PM
firestorm firestorm is offline
Rep: 10 Posts: 16
Go to Michigan Wheel I think it is www.miwheel.com they will do a prop sizing for you just fill in the blanks on their form and they will email you back in a few days with the correct prop for your boat and application.
bigger props faster ship? Peter H Boatbuilding 23 02-01-2010 01:08 PM
Free Propeller Calculation !!! propellerman Boat Design 2 04-15-2005 04:47 AM
Free Propeller Calculation !!! propellerman Wooden Boat Building and Restoration 0 04-02-2005 07:58 AM
Free Propeller Calculation !!! propellerman DIY Marinizing 0 03-31-2005 12:57 AM
