Old 03-05-2007, 04:37 PM
fastribs fastribs is offline
Rep: 10 Posts: 2
Prolines to Rhino
Anyone with experience in transferring hull lines from Prolines (Basic-2D) to Rhino?
I'm new at this, experimenting with Rhino. I've imported my hulls into Rhino but end up with a "flat" stack of sections in one dimension on Rhino. Does Rhino let you "pull-through" the stack of sections to end up up with a 3D hull?.
Thanks, Newbie, Wesltlawn background before CAD was accepted.
Old 03-05-2007, 07:16 PM
CGN CGN is offline
Rep: 121 Posts: 547
There is no way to obtain the same surfaces from prolines (Basic version) to rhino, it is possible to export 3D dxf (Prolines to 3D Dxf), find in the manual how to do it, and use rhino to "skin" trough this sections and waterlines.
The other way is to forget about prolines bite the bullet and buy something like delftship or even probasic, you will waste so much time triying to re-create an exact model from prolines in rhino. prolines is a good software but without support for iges is just a PITA.
Old 03-05-2007, 09:21 PM
Rep: 10 Posts: 2
CGN, thanks for your feedback. Delftship may be a good option although I hate to leave Prolines, good software and Vacanti has always been very responsive. Just can't see getting into Rhino developing hull, skins and rendering without a solid hydrostatics analysis behind.
Best
Old 03-05-2007, 11:31 PM
CGN CGN is offline
Rep: 121 Posts: 547
Hi FastRibs, I know what you mean, i'm an ex user of prolines (Basic Version) myself but is somewhere sitting on an obscure corner, good software but without support for iges it was hard to keep using it so i switched to Prosurf probably the only one that since the begining had the iges option on it's basic version and also it saves GHS files, and after that freeship now delftship, all the export options that you may need and easy to use.
But not everything is bulletproof, there is always some "tweak" here and there to do to a GHS file, but i have no doubt that delftship or prosurf for the price will save you a lot of time.
cheers
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 03:55 AM
how to design hydrofoil with prolines misbah Software 0 12-27-2004 06:30 PM
Prolines sucks... Sean Herron Software 2 10-11-2004 12:32 AM
prolines help crip Software 7 10-09-2003 10:14 PM
ProSurf 3 vs Prolines 7 Tom_McGuinness Software 7 09-21-2003 08:27 AM
