Old 03-19-2009, 07:28 PM
lyqqmxm lyqqmxm is offline
Rep: 10 Posts: 20
Problem of maxsurf14 to Rhino4
Hello all
i'm an user of maxsurf14 academic, but i export my model to Rhino4, i coun't use some command eg. projection, trim and so on.
Help!
Robin
Old 04-01-2009, 12:52 AM
a78's Avatar
a78 a78 is offline
Rep: 10 Posts: 8
hi,
first I should to know how you exported your maxsurf model to rhino,
because I don't have any problem with it (export maxsurf model to rhino).
here are steps by steps I ussually do to export maxsurf model to rhino:
1. export to 3D iges (and select nurbs surfaces option)
2. open rhino and import the iges file.
note: also give attention with the units option.
cmiiw
Old 04-01-2009, 03:36 AM
formsys formsys is offline
formsys
Rep: 37 Posts: 73
By the way, you dont have to use IGES any more to go to and from Maxsurf and Rhino. Maxsurf reads and writes Rhino 3DM files which is a better option as it preserves names, colours etc and avoids problems with units and so on.
Old 04-01-2009, 05:58 AM
Rep: 10 Posts: 20
HI:
First, i use maxsurf14 academic which including function of exporting to
Rhino 3dm file directly.
Second, the version only make three surfase, so i had to model hull with
chine by "compact" and "group" control point in one surfase.
Robin
Old 04-01-2009, 06:18 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
Lyqqmxm rhino does seem to have trouble with surfaces with compacted points done in maxsurf and trimming. You may need to split the surface up in rhino using the “divide surface on creases”,then do your trimming, then join the surfaces back together.
Old 04-02-2009, 02:21 AM
Rep: 10 Posts: 20
Thank above!
Where is the command of "divide surface on creases"
Robin
Old 04-02-2009, 04:15 AM
Rep: 547 Posts: 540
look in "surfaces">"surface edit tools"
Old 04-02-2009, 08:25 PM
Rep: 10 Posts: 20
Thank you!
Problem has been solved, but when i split the surface on the chine, each
surface will appear multiknots on edge. i use "removeMultiKnotSrf" in surface
tool but no effect. How delete the multiknots in the case of keeping shape?
Robin
Old 04-02-2009, 10:03 PM
formsys
Rep: 37 Posts: 73
You will have to ask the Rhino experts about knot deletion but I dont think its possible to delete the knots without changing the surface shape, however the change may be minor depending on what the knot was used for. As I mentioned before, avoiding using those knot vector changes in the first place is the best way to ensure fair surfaces.
Old 04-03-2009, 12:52 AM
Rep: 547 Posts: 540
lyqqmxm here is another work around for the compaction problem. After taking the surface into rhino from maxsurf , show all the control points, pick one of the points of the two compacted and move it away from the other, it only needs to be a little less than a mm. Rhino then seems to be happy to then trim that surface.
Old 04-03-2009, 03:01 AM
Rep: 10 Posts: 20
Good idea!
And wish Rhino invent a new shortcut command for it
Robin
Please help, I have a problem.... JOHNSCOTT64 Open Discussion: All Things Boats & Boating 19 05-09-2009 12:25 AM
Problem!!! surfingyetty Multihulls 3 12-22-2008 05:18 PM
TV problem yipster OnBoard Electronics & Controls 12 11-07-2007 09:32 AM
Do I have a problem?? hiracer Metal Boat Building 16 08-29-2006 07:05 PM
problem electricvoodoo Boatbuilding 7 09-09-2005 05:00 AM
