Old 02-13-2006, 09:33 PM
chango chango is offline
Rep: 10 Posts: 2
Problem: Lightship displacement using movement of weights
Hi,
I`m a student and I need some software or some tool of Hydromax for calculation of weight, LCG, VCG and TCG of lightship using a values of inclination experiment, like medium draft at amidships and values of the movement of weights.
I`m really complicated
Thanks.
Felipe Angulo A.
Valdivia , Chile.
Old 02-15-2006, 05:26 AM
Rep: 1729 Posts: 2,462
Look at the student version of maxsurf perhaps?
Alternatively get hold of rhino which will give you the basic hydrostatics and rhinomarine will give you the rest. I think you get to use rhinomarine free for a month.
Hope this helps
Mike Johns.
Old 02-16-2006, 02:38 AM
Rep: 206 Posts: 391
Felipe
If you have a Maxsurf model of the hull, use the specified condition analysis in Hydromax to specify the forward and aft drafts, or amidships draft and trim. From this you can determine the displacement, LCB and KMt at the inclined condition. The LCB position will give you the required LCG for that trim and displacement.
The transverse shift in the CG and the measured heel angle allow you to estimate the GMt value. Subtracting GMt from your KMt value will give you your KG (i.e. VCG) value.
For more explanation of this have a look at http://www.usna.edu/NAOE/courses/en200/ch03.pdf starting on page 29
regards
Andrew
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 02-22-2006, 12:36 PM
Rep: 10 Posts: 2
Thanks for your answer. I´ve read this document. Finally I have to solve this problem using a excel.
And I´m sorry for my english....
Thanks
Felipe Angulo A.
Spline Weights Guest Boat Design 32 11-30-2005 02:40 AM
Need spline weights? 8knots Boat Design 8 04-04-2005 11:01 PM
Balanced yacht and LCF movement when healed in MaxSurf Mikey Boat Design 2 03-25-2005 06:03 AM
Tansom Movement in Vkiking HELP! 46vky Boat Design 6 01-11-2005 07:47 PM
Maxsurf problem - deck affects displacement PaulCoffin Software 2 04-29-2004 05:57 PM
