Old 08-09-2010, 09:00 PM
jprevj jprevj is offline
Rep: 10 Posts: 5
Point Stuck On Corner In FreeShip
I'm using FreeShip 2.6. I have a control point that is stuck on corner. I can uncheck it but the point stays a corner and the point dialog will always come back with the corner box checked. I have shutdown FreeShip and also shut down windows and reopened. I have tried to delete it thinking I have two points there but it takes a section of the hull. Anyone have any ideas or has anyone run into this before?
Thanks!
Though I had found answer in old post to collapse point. Doesn't work. I haven't been able to make any of the other suggestion work either. But might be missing something.
This is a modified scooter for very shallow coastal work. 6" or less. Will have jet drive and tunnel. I guess it's easy to see the offending point.
fbm file removed. I just redesigned the hull. Thanks for the replies.
Old 08-10-2010, 03:41 AM
magwas magwas is offline
Rep: 47 Posts: 270
Can you post your fbm file?
Old 08-10-2010, 04:27 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Check if you have a sharp (crease) edge attached to the point.
Old 08-10-2010, 02:05 PM
mick_allen mick_allen is offline
Rep: 47 Posts: 19
- do you have a layer turned off that has something attached to that point?
- is that point in line with other points that may have a 'hidden' (because all in line) surface between them?
- check to see if you have a surface that is bent back on itself - sometimes that is quite confusing.
helpful thing to do is make a copy and start deleting stuff one at a time to see what happens.
Old 08-11-2010, 11:50 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
You cannot change the corner property if 3 or more crease (red) edges meet in that particular point.
Corner Fillets / Inside Radius Creation Xander Fiberglass and Composite Boat Building 19 01-05-2010 06:20 PM
Control Point Problem in Freeship 2.6 jprevj Software 3 09-19-2008 11:14 AM
Fiberglass taping an inside corner MarkIFC Fiberglass and Composite Boat Building 13 12-15-2007 10:47 PM
How to fillet corner of two intersecting pieces Grant Nelson Software 1 09-13-2006 02:39 AM
Keel design and corner hull roberto.bertoli Boat Design 1 10-26-2004 09:28 PM
