Old 10-11-2011, 02:36 PM
metin_mehel metin_mehel is offline
mech.eng.
Rep: 10 Posts: 92
please somebody help to rhino offset
Can somebody offset this hull 10mm to inside and trim its extensions? then please send to me? I think it is imposible.
Old 10-11-2011, 03:07 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
The boat is only 7.50 millimeters long in your model. You have units set to millimeters. Offsetting by 10mm is meaningless.
I assume you intended for it to be 7.5 meters long. That may be the cause of your problems
David Cockey
Old 10-11-2011, 03:14 PM
mech.eng.
Rep: 10 Posts: 92
what should I do? could you please write to me?
Thanks
Old 10-11-2011, 03:30 PM
Olav's Avatar
Olav Olav is offline
cand. arch. nav.
Rep: 337 Posts: 198
Hope this works for you...
I used Rhino to make a solid from both the hull and the cabin, saved each of it as a STEP 214 file, opened them in SolidWorks and made the 10 mm wall thickness thing there (since I'm much more comfortable with SW than with Rhino). After that I re-exported the models via IGES back to Rhino and saved them as the attached *.3dm file.
Edit: David Cockey is right, the boat's length is only 7.5 mm, so the 10 mm offset is actually 0.01 mm. However, it shouldn't be a problem to scale the model in Rhino by a factor of 1000 using the "scale 3D" command.
All the best, Olav GER-1045 ____/)_/)/)___
Old 10-11-2011, 04:12 PM
mech.eng.
Rep: 10 Posts: 92
Olav,I want it to make with Rhino. I think this should be easy. I corrected the units. however it sometimes trim and sometimes not trim and I dont understan why. I also extend the surface but unfortunately...
Old 10-11-2011, 04:21 PM
mech.eng.
Rep: 10 Posts: 92
I made `extend trimmed surface` and it worked
Old 10-11-2011, 04:22 PM
mech.eng.
Rep: 10 Posts: 92
no sorry, it trimmed but it disturbed the shape
Old 10-11-2011, 04:26 PM
Engineer
Use Untrim followed by ExtendSrf instead
David Cockey
Old 10-12-2011, 03:01 AM
gwboats gwboats is offline
Naval Architect
Rep: 68 Posts: 89
Inside Surfaces
metin_mehel,
A method I have used for flat panels in the past is:
Offset your surfaces - check offset arrows and flip the right way if needed.
Go to Curve>Curve from Objects>Intersection.
Create new curves at all inner surface intersections and sheer.
Use Sweep 2 Rails using the longitudinal curves as rails and the end intersections as cross section curves.
Hope this helps.
Regards,
Graham
Old 10-12-2011, 03:34 AM
mech.eng.
Rep: 10 Posts: 92
gwboats it is a good idea I think. Do you think the curves are generated properly in my model?
Old 10-12-2011, 05:22 AM
Naval Architect
Rep: 68 Posts: 89
Inside Surfaces
metin_mehel,
Your surfaces look OK. Not too many control points and reasonable spacing.
For the curves generated in my previous method, it can help to:
Select curve
Go to Edit>Rebuild
Set Point Count to say 8 and Degree to say 3
Click Preview (not OK) and the maximum deviation from original will be displayed
If this is acceptable then Click OK, otherwise increase Point Count slightly to get acceptable value
Use rebuilt curves to generate surfaces as before.
Cheers,
Graham
Old 10-12-2011, 05:48 AM
mech.eng.
Rep: 10 Posts: 92
how do you know that "Your surfaces look OK. Not too many control points and reasonable spacing." which command?
I have another question. This model was builded by me with delftship. I want to produce this boat and sell. In order to reduce machining job (actually beveling), I made this hull straight. Do you think this boat is aesthetic?
Do you create hull by rhino? Or exporting from any shipdesign program. My version of Rhino does not calculate me Cp value... Can you model this kind of boat in Rhino too?
Old 10-12-2011, 10:03 AM
Naval Architect
Rep: 68 Posts: 89
Inside Surfaces
metin_mehel,
From your questions I think it is time for you to do a few Rhino tutorials. There are plenty around including marine ones, try a Google search. These will help you with the more common commands and show you what Rhino can do.
For now, to see the Control Points for a surface:
Highlight the surface
Go to Edit>Control Points>Control Points On
You should then see a mesh with Control Points which will indicate the complexity of your surface. As for Curves you can rebuild surfaces but take note of the maximum deviation as you did for the Curves. Alternatively you can push and pull Control Points for fine adjustment.
Your boat looks OK to me but it is not the sort of style I really get involved in. Maybe you should do some market research and see what potential customers like.
For small craft I use Maxsurf for hull design as it is fairly quick to get a reasonable shape and includes hydostatics. For Rhino there are add-ins such as Rhinomarine (obsolete but still around and useful) or Orca 3D which will probably answer your form questions.
Cheers,
Graham
Old 10-12-2011, 10:50 AM
Engineer
Cp can be quickly calculated using several Rhino commands.
Remeber the definition of Cp
Cp = Immersed Volume / (LWL x Largest Immersed Cross-sectional Area)
Hydrostatics command provides immersed volume and LWL
For largest immersed cross-sectional area:
Create a cross-section of the hull outer surface at the appropriate location.
Trim the cross-section at the waterline height.
Close the top of the closed cross-section with a straight line and join the cross-section curves into a single polyline.
Use Area command to calculate the area.
Calculate Cp using the immersed volume, LWL and Area
Remember that an exact value of Cp is not critical. Many other factors will affect performance more than a difference in Cp of .001. Check that Cp is within .01 or the desired value.
David Cockey
Old 10-12-2011, 11:19 AM
mech.eng.
Rep: 10 Posts: 92
Thank you very much guys for these informations.
I have principle of yatch design book. It says use cp .56 and lcb -3.4%. But correcting the shape and recalculating cp is hard work.
Thanks again
Rhino Rhino Rhino (hull thickness, offset surface, and unrolldvp for cnc cutting) metin_mehel Software 11 10-11-2011 12:10 AM
Offset Centerboards Bruce46 Boat Design 12 10-19-2010 03:00 PM
i need offset for tugboat engin Boat Design 2 02-19-2010 04:47 PM
Offset tables john.G Software 6 05-07-2009 04:33 PM
offset from rhino 3 Ahmed Wahab Software 0 11-08-2007 08:03 AM
