Old 10-12-2011, 12:38 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Originally Posted by metin_mehel View Post
Thank you very much guys for these informations.
I have principle of yatch design book. It says use cp .56 and lcb -3.4%. But correcting the shape and recalculating cp is hard work.
Thanks again
Designing a good boat isn't simple or easy. It's much more complicated than the design of many mechanical devices.
It takes me less than 5 minutes to calculate Cp using the method I described above.
What requirements lead to those values of Cp and Lcb? How sensitive is meeting the requirements to those parameters? What other parameters or dimensions do you also have requirements for?
David Cockey
Old 10-12-2011, 02:51 PM
metin_mehel metin_mehel is offline
mech.eng.
Rep: 10 Posts: 92
The book says not right cp and lcb combinations creates %1-%5*displacement(kg)/100 additional resistance.
Mechanical engineerin is more simple. Yatch design requires very wide range knowledge and experience on both designing and building.
Old 10-12-2011, 02:53 PM
mech.eng.
Rep: 10 Posts: 92
sorry %0-%0.1* ... correct
Rhino Rhino Rhino (hull thickness, offset surface, and unrolldvp for cnc cutting) metin_mehel Software 11 10-11-2011 12:10 AM
Offset Centerboards Bruce46 Boat Design 12 10-19-2010 03:00 PM
i need offset for tugboat engin Boat Design 2 02-19-2010 04:47 PM
Offset tables john.G Software 6 05-07-2009 04:33 PM
offset from rhino 3 Ahmed Wahab Software 0 11-08-2007 08:03 AM
