Old 11-04-2004, 09:26 AM
L.DOSSO L.DOSSO is offline
Rep: 9 Posts: 71
pilot 3D-does it only use Nurbs surfaces?
Are there software a little less good than rhino but sold at a less price.around 600dollars or euros.What do you think of pilot 3Dmade by the same company which created prosurf? How do you call surface which are not nurbS surfaces?For instance if you have your hull created in prosurf,you export it in think3,and then you create a "loft" surf between starb&port sheeline,what kind is this surface of? lucas
Old 11-11-2004, 10:22 PM
CGN CGN is offline
Rep: 121 Posts: 547
Touchcad is your best option, at least it can do some of rhino stuff and can do some of prosurf stuff, best choice, the only problem I see with touchcad is the lack of formats to export to, for example, it has no iges, or step export and import (maybe it has that feature by now) which are some of the most used way to export a nurb surface to other systems like think3 or solidworks etc..
a surface that is not a nurb surface, usually is a mesh, it can be something else but most of the time you only work either with nurb surfaces or meshes, meshes are not so easy to edit, nurbs are becoming a good way to represent surfaces like the ones for a hull and more "editable" in other software's.
"if you have your hull created in prosurf,you export it in think3,and then you create a "loft" surf between starb&port sheeline,what kind is this surface of?"
well.. the actual surface is the deck...and is a nurb surface.....lofting, is just a way to create a surface.
now...what I like to do in solidworks is to create my models in rhino and export the surfaces to solidworks, and create the structure "in" the surface, that way if I want to change anything on my surface all my structure changes with it. but...so I'm guessing that you want to use think3 (based on your example) then...you probably export only the sections of your boat as a dxf and use this ones as a reference in think3 to model the boat structure.
Old 11-12-2004, 11:26 AM
Rep: 9 Posts: 71
than you CGN
Old 11-13-2004, 06:27 AM
ludesign ludesign is offline
Rep: 54 Posts: 177
No IGES in TouchCAD yet but in the upcomming 3.5 you can export NURBS objecs to VectorWorks, both as solid NURBS surfaces and as ordinary NURBS surfaces and then re-export it as IGES. I have tried these files with many high end programs such as SolidWorks, Pro-E and similar and they work very well. I think VectorWorks actually use the same 3D kernel as SolidWorks and Solid Edge, but costs a lot less. Around here, actually less than AutoCAD LT, making it an excellent budget option, both for 2D drafting and 3D solid modeling.
Claes Lundstrom
Maxsurf Q - Bonding Intersecting surfaces ? cmcguinness Software 1 02-17-2005 12:07 AM
3D v 2D guest12020101217 Software 10 03-24-2004 07:33 AM
Yacht interior layout Polarity Software 48 04-13-2002 09:12 PM
