  #31
Old 07-08-2011, 02:59 PM
CaptBill's Avatar
CaptBill CaptBill is offline
CaptBill
Rep: 64 Posts: 181
Originally Posted by Olav View Post
yipster,
there is an input file in the examples folder of PDStrip; see also attached file (I had to zip it to make it a format that's accepted as an attachment by the forum's software).
The output in another window of the GUI is lots of numbers without further explanation - I'm still struggling to find out their exact meaning...
This gives a good idea of the framework interface needed (input side). What I wonder is if the output values (calculated from these inputs) returns values that 'seed' the next computation. In other words, the output is a snapshot in linear time (array of 3d points), the next round of computing is a snapshot in the next 'timeframe', the third iteration is the next timeframe, etc etc. One execution per frame (like a video frame in time) and each frame (the output values from the last frame) provides the values for the next frame in time. so it needs to fire sequentially upon a time frame to provide a sequence of video frames. Notice the array values after wave steepness/wave height. The following values (looks like array vals) are what needs to be reseeded on a timeframe (with computed vals from last frame outputs)......possibly?
This might be why it is hard to determine how it should be used. If that is the case then this should be a simple matter to get up and running.
Abrahams Altar FOUND
See Footage Jerusalem
http://MountoftheLORD.blogspot.com
  #32
Old 07-09-2011, 08:08 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
downloaded the compiler recomended, dont know but reading up on how to execute
  #33
Old 07-09-2011, 08:10 AM
yipster's Avatar
and a pic
  #34
Old 07-09-2011, 08:44 AM
yipster's Avatar
i'm pretty dumb, havent found the right manual and give up for now
  #35
Old 07-10-2011, 10:53 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
Bill, I think you are labouring under the belief that pdStrip is a time-domain code. It isn't. The output is the vessel response to a certain incident wave frequency.
The Wiki has a definition of some of the output files (including the responses), but I haven't yet found any concrete evidence to prove whether they are position, velocity or acceleration RAOs. If anyone works it out could they post it on the wiki?
Thanks,
Tim B.
  #36
Old 07-11-2011, 09:52 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
If that's the actual state of the things, then this software is useless.
  #37
Old 07-11-2011, 11:35 AM
yipster's Avatar
was just wondering bout the state of it becouse i would like to see what it can do. maybe ask the devellopers?
  #38
Old 07-11-2011, 12:39 PM
Could do, at the risk of admitting my only too extensive ignorance. I have a time-domain code underway, but at the moment I'm just too busy to compare results.
Daiquiri, I agree, it is rather important to understand the output!
Tim B.
  #39
Old 07-11-2011, 10:11 PM
CaptBill's Avatar
CaptBill
Rep: 64 Posts: 181
Well I found the best place on God's green earth for hiring a bounty hunter for you fellows (HAHA)
Have a look at how fast these guys work (This was today)
http://www.lazarus.freepascal.org/in...c,13795.0.html
Then you might find this thread to be quite an eye opening surprize....
http://www.lazarus.freepascal.org/in...c,13754.0.html
They are very excited for good reason there right now. They might do it for free just to show off,hahaha.
PDStrip, free strip theory program Martijn_vE Software 47 01-03-2012 07:06 AM
Wheelhouse windows Johns1152 Boatbuilding 79 01-28-2011 12:08 PM
Windows dick Metal Boat Building 3 10-05-2009 03:47 PM
Where can I get windows from? mongo75 Fiberglass and Composite Boat Building 2 08-25-2008 09:43 AM
Streamlining Windows XP (?) LP General Computing 6 01-18-2007 12:45 AM
