  #46
Old 12-14-2011, 09:39 AM
CWTeebs CWTeebs is offline
USCG 3AE
Rep: 124 Posts: 87
I'm having trouble finding any documentation about the underlying theory. Is it similar to VisualSMP?
  #47
Old 12-15-2011, 07:22 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
The underlying theory for PD-Strip is well documented, and is available from the software repository. Here : http://opendynamics.cvs.sourceforge....on.ps?view=log
The thoery behind openDynamics is quite detailed for each individual component. Essentially, it is based on adding up all the forces at each point on the components, then moving the model accordingly. Each component will have it's own detailed theory, which will be described separately (for waves, foils, hull etc). openDynamics is not based on a strip-theory method. It is (primarily) a time-domain, volumetric method.
In conclusion, pdStrip is similar to VisualSMP (just without most of the visual at the moment), and openDynamics isn't at all similar.
Hope this helps,
Tim B.
  #48
Old 01-03-2012, 07:06 AM
imita_seixo imita_seixo is offline
seakeeper vs pdstrip
Dear Gtampier:
I found your post really interesting. Do you have the geometry and results for this barge? We are having problems matching a similar case with both codes.
Sincerely.
Antonio
Originally Posted by gtampier View Post
I have some good news. The Absolute terms (1, 2, 3) for translations and rotations are the 6 RAOs. I quote the user manual in p.10:
If you give as input different wave lengths you will get results for different encounter freqs. Here as example some results:
Code:
wave circ. frequency 1.700
 encounter frequency  3.173
 wave length           21.33
 wave number          0.2946
 wave angle           180.0
 speed                 5.00
  wetted transom?     T
  log(determinant)     87.82  12.41
              Real part(1)  Imagin.part(1)    Abs(1)  Real part(2)  Imagin.part(2)    Abs(2)  Real part(3)  Imagin.part(3)    Abs(3)
 Translation        -0.000       -0.011        0.011        -0.000       -0.000        0.000         0.100       -0.002        0.100
 Rotation/k          0.000       -0.000        0.000        -0.000       -0.006        0.006         0.000       -0.000        0.000
I'm comparing results of PDSTRIP with SEAWAY and SEAKEEPER (Maxsurf), and for a box-shaped barge they seem OK. I'm calculating a containership now, I will tell you about the results later...
Speed Strip tongue-and-groove strip planking Jeff Materials 38 08-04-2009 11:12 PM
Propeller Speed Theory batboat Props 9 05-23-2009 06:29 PM
FREE! 31' Sea Ray Sedan Project FREE! drs3317 Marketplace 10 07-17-2006 11:37 AM
Propeller Theory - upstream kach22i Props 23 04-10-2006 12:32 PM
Analytical propeller theory Guest Boat Design 8 11-12-2003 01:57 PM
