| PDF's into AutoCAD Many manufacturers post drawings of their products for download in a PDF format. Is it possible to import a PDF drawing into AutoCAD?
| Corel Draw Corel Draw can import PDF and export to DXF. Working trial version is available for download. |
| Vector images Of course this only work for vector images. If PDF contains bitmaps you will be able to extract them using Corel Draw and use them as a background image in autocad for tracing. Or use tre tracing program in Corel package and clean it up in Autocad. |
| Rhino also imports pdf files. As does Adobe Illustrator. |
| many converters out there, but some of them convert acrobat format to raster image, to be really useful you must convert it to a vectorized image try aidecad, a pdf to vector dxf converter: www.aidecad.com you can download a free trial version from their site,install it & just convert the original pdf to dxf format, import it on autocad and just done. you can stretch, scale & modify the vectorized lines.... ![]() |
| Insert Try "Insert" and "raster image" Sometime you have to save the pdf file as Tiff but that can be done with the Acrobate Reader Hans |
| In addition to the previously mentioned Rhino PDF import, I use a freeware program called Wintopo to convert raster to vector. Here is the website: http://wintopo.com/ With PDF files that Rhino cannot deal with, I cut and past the detail out of the pdf into Microsoft "Paint", save it as a JPG, open it in Wintopo, and save it as DXF. Once in DXF, I open it in AutoCAD, scale and clean the drawing and its done. It souunds like allot of file to file to file business, but you get practiced and it is allot faster then redrawing the detail from scratch. |
| AutoCAD changing shapes... | Willallison | Software | 3 | 03-29-2006 05:15 AM |
| AutoCAD sub-layers? | Willallison | Software | 8 | 08-29-2005 10:43 PM |
| Margins in AutoCAD | Willallison | Software | 3 | 06-17-2005 03:54 AM |
| autocad question | joeypfeil | Software | 3 | 01-25-2004 07:05 PM |
| AutoCad Blocks | BrettM | Software | 7 | 09-02-2003 04:59 PM |
