Old 10-13-2010, 11:47 PM
ThomD ThomD is offline
Rep: 98 Posts: 375
PDF to DXF
Anyone know a reliable, free, way of doing this without malware, etc...
In my particular case, the drawings I need to convert are relatively simple, if that makes any difference.
Thanks
Old 10-14-2010, 01:11 AM
Olav's Avatar
Olav Olav is offline
cand. arch. nav.
Rep: 337 Posts: 198
I use PDF2DXF. Even the free trial version does the job for me.
Complex drawings will create relatively large dxf drawings as circles and splines will be converted as polylines only. If your drawings are simple, you'll be better off.
All the best, Olav GER-1045 ____/)_/)/)___
Old 10-14-2010, 05:48 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
I use and sell another PDF2DXF program.
That one, and I guess all others also, can only convert vector based pdfs, not raster. That means you can convert pdfs that origins from a CAD program but not a scanned paper drawing for example.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 10-14-2010, 10:10 PM
Olav's Avatar
cand. arch. nav.
Rep: 337 Posts: 198
To convert pictures (e.g. scanned drawings) to DXF the guy from my previous post has a solution too: Paper/Picture2DXF
The resulting DXFs occasionally need a bit of love and care, but nevertheless it's a useful tool.
Old 10-15-2010, 02:20 AM
Raggi_Thor's Avatar
Nice, I tried it.
Here is a tip for new users, after converting or importing, use first Quick Select or similar to select all lines or plines with length below a certain value, for example 30mm in my test drawing, then Polyline Edit or similar (depending on your cad program) and Join with a tolerance.
www.MBOATS.no
Old 10-15-2010, 12:17 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 158
If you have Rhino you can import a pdf into Rhino, then export it as .dxf or.dwg etc. It only works with vector based pdfs and all text and dimensions will be broken up into segments.
Old 10-15-2010, 07:52 PM
apex1
I use "Vector Magic" to vectorize pixel drawings like .jpg .bmp and the like.
Although not perfect (none of them is), it gives good results.
Regards
Richard
MULTIHULL WORLD Mag, Archive Files in pdf format brian eiland Multihulls 1 01-14-2010 12:37 AM
Does anyone know where I can get "Swedish Tanker Series" pdf?? naggar218 Boat Design 1 03-25-2009 01:18 PM
25 foot micro-multihull pdf Gary Baigent Multihulls 3 12-13-2008 05:27 PM
555hg service manual pdf? l2edneck Outboards 0 06-21-2007 11:16 PM
